Is this just me?
JDM-Jonathan David Martin- I own everybody
Is this just me?
Ok, after my car overheated from head lift and my stock head bolts streching, I took it apart, replaced the HG, IMG, put ARP's in, got the head milled and the car hasn't overheat.
The problem I'm having now is the car misfires every cylinder........ I installed Crower valve springs/retainers while the head was off so it's running those right now without the crower cam until it get's here sometime this week.
I'm running k20a injectors, no FMU installed but I have greddy emanage, t25 turbo kit.
Here's the question:
Could the valve springs have anything to do with my car misfiring? Is it because I have the valve springs/retainers without the crower cam? Or could it have to do with the block in some way?
I checked the plugs and even got diff. ones, the car still misfired with new plugs! I'm stuck and need some intelligent 7gen helpers!
thank you guys in advance
I thought milling the head was a no no when it comes to the d17? Did it mess with your compression? Hope you get this resolved and this doesn't open up a big can of worms with your engine.
Hmmm.....maybe your machine shop took a big bite off of the head and it threw your cam timing off, I'd tend to believe it would take a ton of milling to throw misfire codes though. The springs and retainers absolutely have nothing to do with it. Either the thing is knocking pretty bad from someone severely butching the head decking, or your cam timing is off like Andy stated above, which is most likely. Also if you have a leaky HG it can cause random misfires but it seems like this wouldnt be the case seeing how its in every cyl.
http://www.dezod.com/pd_crower_valve_train.cfm
here is dezod.com saying u should use stage 2 or 3 cams....i bet thats the problem!
Official Rattlesnake Hunter
What the ****!^ Ya thats the problem...
I too have a misfire code john!
P301-304 I think is the exact code!
I too changed my pluge three times in 60,000 miles...
I cant figure it out! I just wanted to subscribe
to the thread because its NOT just your 7thgen...
Good Luck to you sir!
Awesome, thanks for all the possible solutions and help everyone has provided me. I'm going to check my timing and once I install the cam I will re-adjust the valves/timing again and see where I'm at!
-John
-John
My timing was off that's why my car was misfiring. Re-adjusted the valves and she sounds good now with the stage 2 turbo cam in. Time for tune!
Nope it won't change anything. The head milling won't change timing either really. All they did was deck it. I ran mine fine and I took like 10 thousandths off or something...
Wanna see a donkey show?
If you think about lining two marks up then remove some space one of the two marks will move to compensate for the lack of material. But if it was surfaced then it wont affect it by much at all. It is always nice to figure out our problems before creating new ones congrats on the fix. Maybe post up some vids after your tune. I love to see people do things to the d17. I wish I had some wevos to do em.
Actually miiling does change cam timing. Not by much but it does throw it off.
I got my cam/springs and retainers installed this weekend and I'll be posting a huge thread of the experience tonight. What do you know I too am throwing misfire codes hehe. The first time it threw a misfire code was on the dyno when the tuner tried to add 1 degree of ignition timing to gain some hp but the ECU went crazy and the car sounded like fire crackers were going off...pop pop pppppoppoppoppp. (We're not really sure why the ecu won't let us add AT LEAST 1 degree). Anyways, I've been getting misfire codes I every now and then I noticed when the car bogs down too low or on really cold mornings and its hard for the car to idle. So far I just bought an OBD2 scanner and just clear them and they go away. Anyone figure out why we're throwing codes. BTW I'm on emanage with a stock cam gear lined up to factory spec, my friend tells me to get a cam gear to play with it to see if the misfire go away. Not sure if thats a solution.
I dont think the cam gear will make the mis fire go away^^^
Crazy!
I have had my mis fire since before my VAFC2 install.
I thought may it might be my spark plugs but the code only goes away
for may be 15,000 miles after I install new plugs...
any one else run on 91 inn there EX that has a mis fire?
Crazy!
when you mill the head it does throws off the cam timing. either get an adjustable cam gear and advance the timing about 3* or buy a thicker head gasket to make up for the difference you lost when you milled the head.
When you make the distance between the cam gear and the crank shorter, and use the same length timing belt (which you have to do) you change the number of teeth that are between the cam and the crank. Its simple math!
Crazy!
Crazy!
Your problem should go away. Official Rattlesnake Hunter
$189 shipped @ http://www.boomslang.us/
Cheaper than Dezod!!!
Crazy!
Crazy!
....and John, you MUST bring me for a ride NOW!!!! or as soon as conveniently possible. I have to see this. Sounds very nice. Good choice with the T25. I was very happy with mine. I love quick spool (as long as it can hold boost pretty well to near redline).
My leggie didnt hit 18psi until 4500 in 1st, lol. After that, it was neck snapping fun, though, lol.
