Plastic Intake Manifold Gasket
Old Oct 9, 2006
andyman97's Avatar
Turbo Guru
Check this out. I ran one when I had the y8 manifold. I put a new oem one back on when I put on the new manifold and I wish I'd kept the old one. The new one is now leaking and I have an annoying *** leak causing a 2k idle. Anyways, they're supposed to be good at dissipating heat and keeping the intake from heatsoaking, check out the thread....
http://www.honda-tech.com/zerothread/1671095
I just ordered a new one today, should be here tomorrow. Shipping was fast, great transaction. I talked to Sean and he was talking about making one for the d17.
All I need to do when I get it is mark and drill a few holes real quick. I will post up results.
Old Oct 9, 2006
Civicman1988's Avatar
i think i am going to pick one up. good post +1 rep
Old Oct 9, 2006
eye_see_you's Avatar
let the devil out
I run the hondata IMG in my type S and it made a huge difference for me so I gotta agree man go that way
Old Oct 9, 2006
abmerop18's Avatar
Jam out with your clam out.
where are the d17 ones? i am failing to see any on there?
Old Oct 9, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
I wonder if the effect is similar to the D17 compared to the K20 im because ours IM is plastic and every application on their has a metal intake manifold.
Old Oct 9, 2006
andyman97's Avatar
Turbo Guru
Yeah, you can bet you'll see gains, even with a plastic im. The problem is that the thin metal gasket doesn't do much in the way of dissipating heat. The problem is the heat coming off of the head goes straight back to the manifold and the manifold has to dissipate the heat. By putting this gasket in, it lowers your actual intake temps at the manifold ports by removing the heat coming off the head so less comes in contact with the manifold itself, allowing the manifold to be more efficient at cooling the intake instead of the heat from the head.
Old Oct 10, 2006
Michalo187's Avatar
Abortion Survivor
good post mang, make show you show us some pics
Old Oct 10, 2006
abmerop18's Avatar
Old Oct 10, 2006
tfnaaf's Avatar
BLDNPSI Mod
im guessing using the D16 one and drilling it to fit D17
Old Oct 11, 2006
andyman97's Avatar
Turbo Guru
Well the d16 gasket doesn't work. There is a port between #2 and 3 that the gasket doesn't quite cover so the d16 one won't work. If he starts making d17 ones, I will post it up.
Old Oct 11, 2006
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
May be if we suggest a group buy.
Old Oct 11, 2006
andyman97's Avatar
Turbo Guru
I talked to sean at power rev today. He's picking up a d17 gasket today and going to start on it tonight. They should be ready to ship in about 1-2 weeks. I also sent him this link so I assume he'll be posting up.
Old Oct 11, 2006
MisterFrankieJ's Avatar
MisterFrankieJ will become famous soon enoughMisterFrankieJ will become famous soon enough
Sweet. Props on doing the leg work andy.
Old Oct 16, 2006
supermex's Avatar
Any progress on this item?
Old Oct 16, 2006
andyman97's Avatar
Turbo Guru
Not sure, I will try to call sean tomorrow and see what the deal is...
Old Oct 17, 2006
Pn0ybOiLiKehOy's Avatar
Pn0ybOiLiKehOy is on a distinguished road
good find..let us know after u talk to him
Old Nov 16, 2006
supermex's Avatar
Yo what happen to this item.
My car will be coming together soon and I could use it
Old Nov 16, 2006
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
cool ****..I have the hondata img on my rsx and I actually felt some gains
Old Nov 16, 2006
andyman97's Avatar
Turbo Guru
I totally forgot about this. I will try and get in touch with him.
Old Nov 17, 2006
AThompson18's Avatar
AThompson18 is an unknown quantity at this point
Yeah if he needs a group buy to do it i am down. I am bout to go to the kms intake manifold, so this gasket would be more than ideal.
Old Nov 17, 2006
Michalo187's Avatar
Abortion Survivor
^^^^ Me too i will buy one for sure
Old Nov 17, 2006
abmerop18's Avatar
ditto
Old Nov 17, 2006
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
i want one 2
Old Nov 17, 2006
supermex's Avatar
Me 3
Old Nov 18, 2006
DaRk_MauL's Avatar
It makes realy a nice blockage between intake and block my friends has
it sitting on his TEG. Noticed take the intake pipe get realy hot too so
i think of getting intake thermo wrap. check it
http://www.thermotec.com/products/full/14002/14002.html
Old Nov 18, 2006
civic05acer's Avatar
civic05acer has a spectacular aura aboutcivic05acer has a spectacular aura aboutcivic05acer has a spectacular aura about
nice im thinkin of getting it to. just so the intake is cooler. cuz it really hot after im driving.
would header wrap work the same?
Old Nov 18, 2006
DaRk_MauL's Avatar
nope it header wrap keeps heat and the intake wrap reflects the heat away
Old Nov 19, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Any of you guys running a CAI or SRI that is aluminum should heat wrap it, especially if you intend on making use of one of these gaskets. The aluminum will rappidly absorb heat from the engine compartment. 7thgens have slightly higher engine compartment temps than previous gens making an aluminum intake slightly less effective. Then only time my intake used to get cool was in sub freezing conditions.
Old Nov 19, 2006
has anyone ever gotten the intake manifold gasket?
Old Nov 19, 2006
wait now im confused one says it ok and the other say no. the exhaust has the heat wrap. but would i be able to use it on the intake.
