is this possible
Old Aug 25, 2006
edrulz2003's Avatar
edrulz2003 will become famous soon enough
is this possible
i was wondering if the s2000 motor could fit in a 7th gen civic...if it does why hasnt anyone done it yet..oh well
Old Aug 25, 2006
genexrocket's Avatar
k20s only without modding much, if it could it prolly would've been done already
Old Aug 25, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Welcome to the forum!
It is not possible (relatively speaking).
Free post.
Old Aug 25, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
Sure an S2k engine could fit into a civic. You could fit alot of different engines into a civic. With an S2k engine it would need to be RWD, so everything would be custom and basically all that you would use from the civic is the shell. The problem is that by the time you spend all of the $ and time into completely altering everything on the car you could have bought and boosted and S2k. This is why it has never been done. If I owned my own giant CNC lathe capable of turning something as large as a driveshaft, had a junk civic laying around, could get an S2k engine cheap and could devote 1yr to the project I might give it a try. Then I think, "a K20a2 engine with hondata/I/h/e makes around 10 less whp, costs a ton less and can be done in a couple of weeks", and I kick my own a$$.
Old Aug 25, 2006
tuner04civic's Avatar
spell check pwns you
yeah its not cost effective to attempt. better off with k20a
Old Aug 25, 2006
varner88's Avatar
...JeRsEy sTyLe...
varner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of lightvarner88 is a glorious beacon of light
yea but how sick would it be if you sed you had a s2k motor and not the same old same old k20
Old Aug 25, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
anything can be done...with $
theres a f20c del sol around here with 2 adders...$$$$=no problems then
Old Aug 25, 2006
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
if this equation is true for you, then yes: you can have an S2000 engine
MONEY>SENSE
Old Aug 25, 2006
EMK20a2's Avatar
K20s still are not old, as far as I know I am one of maybe 3 EM2 swaps in Ohio, and the only swap in NW ohio period (EM2 or any other body).
Old Aug 25, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
Yeah k swaps are still tryin 2 come out. B and H series are old! K series will not get old untill honda makes a new motor better then it. also if you were smart you could do a k24a1 block with a k20a2 head and eather boost it or go n/a and still be cheaper then the sk2 swap and u will have over 350whp and still be unique. everyone with a k swap is unique cuz its just such a beast
Old Aug 26, 2006
varner88's Avatar
...JeRsEy sTyLe...
im not saying there old im saying the k20 is the new b18 being that said everyone wants it and alot of people have them i know alot of k20 swapped cars around here and lots of em2's sum even with k20a with toda kits and **** like that.. im jus saying it would be nice to have another option wouldnt it?
Old Aug 26, 2006
mellow_civic's Avatar
mellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trustedmellow_civic should not be trusted
anything is possible if u have the $$$ and yes u COULD fit an s2k motor but would take so much time and effort, as well as $$
Old Aug 26, 2006
Hurts2bStock's Avatar
Shinier than yours, meatbag
You can put a jet turbine ina 7thgen, a john deer tractor motor.......I thnk the AEM drag car has an NSX motor in it........you can put any motor in any car.........but K's fit, and work well and are putting out plenty of power for our cars.
Old Aug 26, 2006
varner88's Avatar
...JeRsEy sTyLe...
actually the aem drag car has a b18
Old Aug 26, 2006
the 6.5 second one? not on a b man...
NSX7thgen
Old Aug 26, 2006
Michalo187's Avatar
Abortion Survivor
^^^ Yeah that has an nsx motor but look how modified the body is. That hood is as long as a vettes hood.
Old Aug 26, 2006
varner88's Avatar
...JeRsEy sTyLe...
when the first built that aem car is was a diff color and it had a built b18 turbo in it. i watched the interview with the driver but hey maybe they swapped it out?
Old Aug 26, 2006
fatal Error's Avatar
fatal Error is an unknown quantity at this point
I've seen it...A saw a guy at hot import Night like 3 years ago who had an 02, or an 03 with and s2000 tranny and motor he had to cut the floor and reweld it....stretch the frame and a **** load of modding for not that much more HP...Awsome Idea but alot of work,.more than my pockets can afford but if you got the cash and the skill to do it go for it that's F*ckin Awsome !!! RWD Vic...
Old Aug 26, 2006
skipbarber's Avatar
i posted about this a long time ago. f20c has been mated to a k20 trans before. lots of customization involved and it was supposedly installed in a lotus. Some pics were circulating honda-tech at the time, but most peopled deemed them to be photochops. read all about it
http://www.7thgencivic.com/forums/sh...highlight=f20c
Old Aug 26, 2006
DeX's Avatar
DeX
Canadian, Eh!
DeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to allDeX is a name known to all
I think the S2000 head can be mated with the K20 block so you could always do a K swap and then put the S2000 head on it.
Old Aug 28, 2006
EMK20a2's Avatar
^^^^^I don't think that is possible. You would be better just doing the K and then putting on Toda cams, rebuilding the bottom end to handle 9-10K rpms, and tunning it.
Old Sep 7, 2006
blk04civiclx's Avatar
blk04civiclx is an unknown quantity at this point
just buy an s2k and put a civic emblem on the trunk
Old Sep 7, 2006
armieo's Avatar
< My future wife.
Okay I think we need about 48 more people saying that it costs a lot of money and modifications to make it work.
