Engine Swap
Old Jul 25, 2006
BRED civic's Avatar
BRED civic is an unknown quantity at this point
Engine Swap
Can anyone tell me the pros and cons of doing an engine swap with a H22A Type S and k20 Type S. Which is the better bang for the buck.
Thanks
02 civic 4dr
Old Jul 25, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
unless u know someone that can make u custom mounts for the H22 then dont even bother with anything but a K swap
Old Jul 25, 2006
BRED civic's Avatar
Well i guess its a K-swap. Its better anyways from what i hear... now an suggestions on which k20 series i should get?.... pros and cons anyone?
Old Jul 25, 2006
RHCP0801's Avatar
search...k20a2 if you dont really wanna boost, k20a3 is more suitable for boost...than there is the k20a, yes thats a nice one
Old Jul 25, 2006
or if u wanna boost and have a good bottom end u can go with a K24a1 block and a K20a2 head. k24a1 comes out of the CRV
Old Jul 25, 2006
Rennen's Avatar
New Mod on the Block
do the h22... im confident that you can do it... its not that hard
Old Jul 25, 2006
lol @ what he said^^^^
Old Jul 25, 2006
P.O.S.B.A.S.04's Avatar
Ever Wonder What P.O.S.B.A.S. Is An Acronym For
P.O.S.B.A.S.04 will become famous soon enoughP.O.S.B.A.S.04 will become famous soon enough
^^^ do it! i want to see before and after pics!
Old Jul 25, 2006
BRED civic's Avatar
Alright, i talked to some guys from OHC... Ottawa Honda Club and im going to get some help! and yes i plan on taking tones of pics.
Old Jul 25, 2006
of the h22 swap? or k swap??
Old Jul 26, 2006
boxcarracer's Avatar
boxcarracer is a jewel in the roughboxcarracer is a jewel in the roughboxcarracer is a jewel in the rough
lmfao h22??~!?!? oh ****
Old Jul 26, 2006
BRED civic's Avatar
Yah the H22 is a no go, its going to cost just as much as getting a k20. so im going k20 i suppose
Old Jul 26, 2006
Vantage's Avatar
Vantage should not be trusted
going to cost as much+ HOURS AND HOURS of extra work.
Old Jul 26, 2006
TheSmuggler's Avatar
The a3 is not better for boost if you're looking for serious numbers. Once it gets to around 300 it has a NAST case of crankwalk that can appear, and that will end your day of fun real fast. Generally the a3 is cheaper, but has a lower output and dosen't have true vtec.
The a2 is a good setup for boost or allmotor, and will run you a little more. You'll essentially have alot more options with this motor. You can also do a frank with a k24 bottom end and an a2 head. You'll need to be careful though of high revs on this one, and make sure a shop that KNOWS what they're doing undertakes this.
Then you have the lovely a, which is better suited for an all motor setup, but under the right circumstances can take a moderate amount of boost. This one generally runs in the 5k dollar range, comes with a higher compression and more horsepower than an a2.
The most common swpa that people are doing is a straight a2 swap, with a few franks and z1's on the sides. =)
RicoSuave
May 20, 2015 01:57 AM
cloudguy
Apr 28, 2015 05:02 AM
MyOtherRideIsBritney
Jan 20, 2002 03:16 PM
robbclark1
Dec 12, 2001 12:18 PM
supercivic01
South
Nov 30, 2001 11:27 AM
