KPRO question
Old Jul 19, 2006
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
KPRO question
Hi, im about to trade some stuff for a Kpro ECU and whanted to know if there is any phisical way of recognicing a Kpro´ed Type S ecu, also is there anyway to know if its working if i dont have a running car right now, like with a laptop or something?
Any help will be apreciated, thanks...
Old Jul 20, 2006
Michalo187's Avatar
Abortion Survivor
I don't know much about this but if its like any other computer management i have seen it should have a serial number and part number so look up the part number and make sure it matches. And as for checking it I doubt you can check it unless you run your car but i could be wrong.
Old Jul 20, 2006
HondaLuver's Avatar
Its a celebration bitches!
A krpo'd ecu will have a ubs port on it compared to a regular ecu.
if you want a certain type of ecu such as a type S. look for the code in the serial # PRB
prc is Type R
Old Jul 20, 2006
doubledeuce2k2's Avatar
cases can always be changed (mine is in a stock civic lx case, so a PND or other case could be swapped too i presume), so i guess without hooking it up, you couldn't really know. if someone you know has a type s, plug it up, and see if the reverse lockout solenoid is functional i guess...
Old Jul 21, 2006
i have a friend with a swaped EM2 so will try out on that..
Old Jul 22, 2006
boosted.es2's Avatar
boosted.es2 is a jewel in the roughboosted.es2 is a jewel in the roughboosted.es2 is a jewel in the rough
maybe you should go to k20.org just to be sure, i bet they would know
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
junkyardguy
Sep 2, 2015 06:07 PM
martinsmartin
Aug 15, 2015 07:34 PM
