What did you guys use for lines??
Old Jun 19, 2006
EMK20a2's Avatar
EMK20a2 will become famous soon enoughEMK20a2 will become famous soon enough
K20a2 into an EM2
For my fuel send I used the goodyear 300psi fuel injector line. I will try to run it as straight as possible. Where it connects to the fuel line I am going to use the civic clip with the line slid over it so I don't crush the line with a hose clamp.
For my fuel return I am using a slightly lower quality injector line also rated to 300psi without the plastic insert. I am also going to run this in the straitest line possible. I am using clamps on both ends since there is not as much pressure and I won't need to really crank them down.
For my heater hoses I am using the strait goodyear heater hose material and runing it in the best line possible.
Do you swap guys see any potential problems with this setup?? I am to cheap to pay $100 from the dealership to do the same thing. I got all of this for $20 at autozone. Do you think I am cutting corners in the wrong spot??
RIPSAW
Nov 6, 2015 04:36 AM
jordan1794
Jun 8, 2015 04:03 AM
beveragemp
May 25, 2015 07:11 PM
wsking77
Aug 29, 2001 05:34 PM
