K20A Head, K24 Block, and FG (06 Si) transmission
Old May 12, 2006
thatsmrgimp2u's Avatar
An elephant.... with stamps for hands.
thatsmrgimp2u is an unknown quantity at this point
Will the mounts that hasport makes get this combo into an em2? I know its a shot in the dark for asking so early in the new si's production but im starting to piece together my motor, and i dont want to spend extra money if it aint gonna work. Im also curious about the wiring between the k20 and k24, does hasport make a hybrid harness for that? Oh, and if i were using the FG transmission what axels would i need? Thanks a bunch for the help....
Old May 12, 2006
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
perhaps you should ask hasport
Old May 12, 2006
djmota's Avatar
why would you want the 06 si trans? for that engine i suggest picking up a 5 speed trans and getting a quaife diff for it. all that torque does not need 6 speeds. you would use a k20a2 harness modified for the swap and the k24 mount kit.
Old May 12, 2006
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
The 2006 si has an LSD doesn't it?
Old May 12, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Yup.
Old May 12, 2006
Thats why i wanted it..... thanks for the info guys...... =)
Old May 12, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
the modified type s (or si) harness that you use to go into our cars will work the same regardless if its a k20 or k24 swap... on the other hand.. i can not vouch for the 06 si version cause i havent worked on it yet.. but as soon as i see someone with the new si i will compare the tranny mount to see if its the same and will let you know once i do find out
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
ClutchMasterOG
May 31, 2015 03:25 AM
Supramk3
May 11, 2015 07:55 PM
supercivic01
South
Nov 30, 2001 11:27 AM
