E-Manage Ultimate Installed, group effort here! UPDATED, IT'S ALIVE!!
Old May 4, 2006
Hwoody77's Avatar
Hwoody77 can only hope to improve
Ok, so I decided to take the plunge on the E-Manage Ultimate.
I got it for a few reasons.
I wanted the launch control rev limiter, I wanted to increase my redline, I liked the mose detailed datalogging, and I wanted to use the autotune feature.
I received it today and decided to do some quick testing to see what would work right off the bat and what wouldn't work.
Some quick throughts on the unit.
The shiny finish looks a lot better than the blue from the older e-manage.
There are a lot more jumpers this time, a total of 18, which have a lot more options.
This unit is straight USB, and it connects A LOT faster than the older e-manage, imports and exports data a lot faster and with a lot less connectivity problems. It was basically just plug and play.
So I plus it in and mess with the jumpers a bit and this is what I have so far.
I got it to run, really good actually. I set it for a K20A and the car starts up fine and it runs fine, only a few minor issues.
The only thing I really got around to testing was the launch control rev limiter...and IT WORKS!!!
I was skeptical about it working on our cars because of the electronic ignition, but it worked.
So tommorow I'm going to see if I can get the whole thing to work, but this is where I need everyone's help.
The extra harness has the following...
Analog Input
Knock Signal 1/ Water Temp Signal
Crank Angle Sensor Input
Injector Output Signal CH1
Injector Output Signal CH2
Injector Output Signal CH3
Analog Output
Knock Signal 2/ Intake Temp Signal
Cam Angle Signal Input
Wehicle Speed Signal Output
Vehicle Speed Signal Input
Injector Output Signal CH4
Injector Output Signal CH5
Injector Output Signal CH6
I'm wondering what I should really be hooking up from this harness tommorow.
The analog input is a generic input that I won't be using. I wired my wideband and the Greddy pressure sensor to the e-manage and I think that's all I'll need for now.
The knock sensor 1 wire, I'm going to hook up to our factor knock sensor.
Now is where I get confused.
The crank angle sensor input, I believe should goto the Crankshaft position wire on the ECU...how essential is this for tuning and datalogging? What is it used for? Is this the wire I should be hooking it up to?
The injector output wires also confuse me, those that have installed the blue e-manage will remember hooking this wires up, this time these are output. After reading the manual, it says that you only hook up the outputs it you want to add and trim fuel VS. just adding fuel. What exactly is trimming fuel?
I plan on hooking up the Intake Air Temperature for datalogging.
Then finally the Cam angle input...do we have this wire in our cars? I'm looking through the ECU pinout and can't find anything.
Could it be top dead center sensor? K Line? Anyone now? What can this be used for?
Well that's it for now, so hel me out here!!
Ask questions, post comments, W/E here.
Pics coming tommorow.
Old May 4, 2006
C2i0v0i1C's Avatar
SuperMODrizd
did the wiring for emanage blue work for the ultimate or is there a conversion harness or what?
did the rev limiter remover worked along with speed limit remover?
Old May 4, 2006
Hwoody77's Avatar
That's one of the things I'm trying to change right now, our rev limiters, do they work by cutting ignition or fuel?
Old May 5, 2006
sspem2's Avatar
em2
fuel
Old May 6, 2006
Hwoody77's Avatar
Originally Posted by 1siksivik
fuel
Are you 100% sure it's fuel cut?
If so we should be able to raise our rev limiters...
Old May 6, 2006
Hwoody77's Avatar
I finished the install yesterday and the car is running 100%, at least so far!!
I was initially having problems with the way the car started/ ran, it was running WAYYY too rich, and I couldn't figure out why.
I set the injector correction feature and I opened up the datalog to see what was going on.
Well, the Blue E-Manage corrects injector size through the MAP Sensor, the Ultimate actually adjusts the injectors themselves, which is a great feature in itself.
I managed to also hook up my AEM Wideband and the Greddy Pressure Sensor.
I just finished wiring up the Crank Angle and Cam Angle, which I was told the Cam Angle would be the Top Dead Center sensor wire going into the ECU.
I love the datalogging, it is a big improvement over the Blue, with a lot of new logging channels.
I got the launch control working and it's awesome.
I still haven't messed with the auto-tune or the rev limiter, but so far it's been awesome.
Now a question, does anyone know what I should be watching with the Ignition Timing(Cam/Crank Angle) to tune the ignition timing? Like what kind of numbers or anything? Thanks!
Old May 6, 2006
sspem2's Avatar
em2
postive. read some threads about rev limiters or threads that ask how fast you been in your civic. think about it the car doesnt cut the ignition cuz the car is still on. lol. so its fuel. im 100% right.
Old May 12, 2006
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
any update?
Old May 14, 2006
2k2whitecivic's Avatar
2k2whitecivic is an unknown quantity at this point
find out if the rev limeter will raise cause if it does im ordering one thats the only realson i dont want emanage blue.
I really wish dezod would make a plug and play harness for the ultimate. That would be so nice.
Last edited by 2k2whitecivic; May 14, 2006 at 03:03 PM. Reason: Automerged Doublepost
Old May 14, 2006
SODJAZERO's Avatar
^^^ i do agree on that one!
Old May 14, 2006
Hwoody77's Avatar
Working on it, I'll have an update tommorow!
Old May 15, 2006
HyaBoosta's Avatar
props on being brave and getting it running. I would like to hear about the target A/F feature working
Old May 15, 2006
skipbarber's Avatar
this makes me want to upgade to the ultimate..
Old May 15, 2006
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
sounds good so far. keep us posted. it does make sense that since the car doesnt die after hitting the revlimiter or the governer that its cutting fuel and not ignition. just to clarify this, would the emanage ultimate work with the d17 also?
Old May 17, 2006
familycar's Avatar
i was told that the ecu reads the rpms off of the crank sensor. if this is the case then there is no way to modify the rev limiter with out the ecu totally f ing everything up. modiflying that signal wont allow the car to run right becasue it will never read the proper signal
Old May 17, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
^^^it is running so far ok
Old May 17, 2006
DUDEitsMATTx's Avatar
DUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura aboutDUDEitsMATTx has a spectacular aura about
Can u use the Launch Rev Limiter on a turbo D17? also how does it work exactly, and does it help u launch?
Old May 17, 2006
ncirom2003's Avatar
would this work with the harnesses for blue? cus i wanted the ultimate but have the blue installed already, if i could just take the old out and put in the new then plug it up id buy one now.
Old May 17, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
no it doesn't work like that.. ultimate using different harnesses, multiple i think.. i wish it was that easy lol
Old May 17, 2006
familycar's Avatar
just because it runs ok now doesnt mean it will allow you to raise the rev limiter. those are 2 completely different things.
Old May 17, 2006
Hwoody77's Avatar
Quick update.
I got the car running perfect right now, and I have a check engine light but it was there prior, so I have to see if any new codes came on.
As for the rev limiter, the problem isn't how the ECU reads the RPMs, because what the E-Manage does is add fuel after the factory ECU stops...I don't see how that would have anything to do with the crank sensor.
As for the install, two of the E-Manage Blue harnesses plus up, but you have to wire another one if you want all of the extra features.
Old May 18, 2006
ncirom2003's Avatar
hwoody is right, because even with my blue, the tuner added fuel past the rev limiter (7k) and now it goes a few hundered past that, however i dont try to push that because its not adding enough fuel for boost.
Old May 19, 2006
skipbarber's Avatar
the plugs are the same, there is just an extra harness you have to buy. The existing ones work just fine though.
Old May 26, 2006
any updates yet, does the rev limiter raise or what?
Old May 26, 2006
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
So how many 7thGener's does it take to install a E-manager?
Old May 27, 2006
XSRCivic's Avatar
How many lame *** supercharged k swapped civic owners can't spell E-M-A-N-A-G-E there is no "R"?! haha a dose of your own medicine.
Maybe its time to look towards the ultimate as an upgrade to the blue.
Old May 30, 2006
familycar's Avatar
xsr- i think youll have a more luck with the EMS. i am pretty much positive that you still cant change the rev limiter on this unit with our cars. but if you can it would be a cheaper alternative but as i said i still dont think its going to work
Old May 30, 2006
XSRCivic's Avatar
im more interested in the standalone mainly due to tuning problems with th emanage. Im not wasting any money going to a dyno with the POS blue. I'm currently saving for the AEM.
Old May 30, 2006
familycar's Avatar
that is the best thing you will do!
Old May 30, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
300 bucks>1600 bucks
