Engine Heating up fast coolant pissing out
Old Apr 29, 2006
  #31
TransformedBG's Avatar
I Hunt Goats, Rams, And Mustangs.
TransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of lightTransformedBG is a glorious beacon of light
Originally Posted by eightball_469
My cars been randomly overheating and the heat quits when I'm stopped. It's been like that since winter and I haven't figured it out yet. The first time it overheated i replaced the thermostat. It didn't do it for again for a long time until I got in a wreck. Past couple weeks its been doing it a lot more and the overflow tank was full and spraying out coolant. I took it to Honda and they couldn't get it to overheat or figure it out. They said its holding pressure. I replaced the thermostat again, replaced the radiator cap, changed coolant and let all air bubbles out. Oil and coolant looked fine when i changed them. last time the temp gauge said it was overheating the fans weren't on when i popped the hood. but if i turn the fans on when its overheating it doesn't help. It USUALLY happens when i'm at a drive-thru but sometimes when i'm driving. and almost always lasts less than a minute. I'm doing a compression test tomorrow. then a leak down test when i get a chance. Hopefully that gives me an answer.
If the water pump was bad would that be why the heat goes cold when I'm stopped?
Check your fans. Does it do it more when your ac is on? I had both my fans go out.. so i found this to be my problem.
Old Apr 29, 2006
  #32
but he just said turning on the fan has no effect.
Old Apr 29, 2006
  #33
Boilermaker1's Avatar
Jap-Euro Fusion
Originally Posted by gearbox
yup i'd say waterpump is a good bet. it may be able to spin slowly when moving but at a stop its not turning and moving the coolant.
IIRC, if you have a siezed water pump, you've also got a siezed timing belt, in which case... that thing isn't going to run. So I'd probably rule out the pump based on the fact that the car does run.
Old Apr 29, 2006
  #34
v8eaterokv6's Avatar
i have a new home do u
it doesnt have to be siezed to not pump any water. could have internal leaks
Old Apr 29, 2006
  #35
BigE19's Avatar
BigE19 has a spectacular aura aboutBigE19 has a spectacular aura about
ok guys the coolant only comes out when i push the car. When i'm hitting about 4 pounds of boost. thats when problems start to occur.
Old May 24, 2007
  #36
DaRk_MauL's Avatar
DaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of lightDaRk_MauL is a glorious beacon of light
Re: Engine Heating up fast coolant pissing out
Originally Posted by xproductionz
when people come into our shop and tells us this things about there cars... most guys automatically its the head gasket...we had a guy come in last week with overheating problems similar to what u say and his water pump went... but gearbox is on the right track... first check the oil... if no signs there check/change the raditor cap...another thing is that u might have air bubbles in your system... and your fan might not be turning on.. also another possible reason might be the water pump... then when all that fails last but not least its the head gasket...
Hey,
Well got a problem and by reading through the post i thing you got it right.
Dont know yet but i will.Here is the problem.
I got a 04ex5sp manual wen i drive it normally the coolant temp wont go to overheating unless i drive alot of miles and then come to a stop the needle
will go all the way up.If i do higher rpm it will happen in shorter time and miles.
Also the water reservoir is pissing out the coolant.if ya know what i mean.
So i start cheking radiator cap,thermostat,oil on the milky stuf,gonna check
radiator on exhaust gasse in the weekend.........sinds the exhaust gasse are
greyich and not white and coolant isnt disapering and the oil is still fine.
NO gasket blown.So what i was thinking at normal 120km/h it get enphough
air cooling but wen i come to a stop the coolant is too hot.......................]
so i think its like you say waterpump sinds its out off plastic.NO good water
circulation thats way coolant gets to hot and bills up more pressure and raditor cap work sinds it going to the reserve tank but it will keeps filling
until it runs over.but ill let you know if it was the waterpump.
also let me know what ya think.
peace
Old May 24, 2007
  #37
andyman97's Avatar
Turbo Guru
Grammar, spelling and punctuation. I won't even try to make that out.
Old May 24, 2007
  #38
doctor's Avatar
Type-Race
doctor will become famous soon enoughdoctor will become famous soon enough
Cut him some slack, hes from Belgium.
Old May 24, 2007
  #39
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Have you ever seen our water pumps? Internal leaks, umm no,definetely not something thats ever going to happen. To many people spread misinformation. Forums are good for people coming up with whacked ideas that others end up taking as fact.
If its happening under boost its defintetly a headgasket. Once you get it back together strap the car on a dyno with a wideband and check your tune. Whatever you do, dont keep driving the car like that.
Old May 26, 2007
  #40
andyman97's Avatar
Turbo Guru
Could you understand any of that? And whether he's from Belgium or anywhere else, I've seen other posts by him that were decipherable.
Xuhme
21
Aug 7, 2023 03:40 PM
thana
Jun 15, 2020 07:05 PM
blazebrown
18
Jun 2, 2019 12:31 PM
CascadiaBlue
Apr 18, 2015 09:13 AM
supercivic01
South
Nov 30, 2001 11:27 AM
