Zex Nitrous Question
Old Apr 25, 2006
Hoosier282's Avatar
Hoosier282 is an unknown quantity at this point
I am on the verge of getting a Zex Nitrous Kit and was curious if anyone has any experience with the kit? The main thing I am debating about is whether or not to get a wideband to monitor the air/fuel. Is this needed or helpful with the Zex Kit, or does the Kit manage this itself?
Old Apr 26, 2006
eye_see_you's Avatar
let the devil out
a A/F gauge may be helpful but you can also use vafc instead i'm not real sure if you actually need one though i'm a boost freak not laughing gas freak.. :lol
Old Apr 26, 2006
free_refil's Avatar
free_refil will become famous soon enoughfree_refil will become famous soon enough
What's bosot?
Old Apr 26, 2006
hexed's Avatar
The black russian
hexed is an unknown quantity at this point
Originally Posted by free_refil
What's bosot?
boost*
Old Apr 26, 2006
djmota's Avatar
The zex wet kit keeps very good af ratios at all bottle pressures. I have a wideband hooked up just to keep an eye on it. It helped once when the fuel jet was clogged..... (first time use on a used kit). But my af ratios have been golden since. So its not exactly required. If you have the cash get one. then if you got a piggy back, you can tune your own fuel curve.
Old Apr 28, 2006
DaddyFatSacks's Avatar
DaddyFatSacks is an unknown quantity at this point
I want a ZEX kit pretty bad too. Lucky!
Old Apr 28, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
if u get an a'/f ratio gauge get the one that can cut power to an 12v sourceif u run and u a/f mix goes north it will cut the system off i had one but i forgot the name of it.look around for one i know there are a few that can do that
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
