Misc. Stuff nuts, bolts, and hose sizes
7thgens official a$$hole
Roaming around the Forum there are alot of threads about what is what size and the search is not always helpful. Stuff like what size bolts do you need to run RSX injectors, Vaccum lines and what not. So this is a thread for any tid-bits than can help a fellow 7thgenner out. I would like it to be strickly Sizes of things and proper torque rateings and stuff. Could somebody help me out with the Torque settings for head studs and bolts? And any other information that you may find helpful? I think this could make life just a little easier. I'll do my best and maybe the mods can help update this thread as well.
fuel rail studs
6mmx1.0
Garrett turbo bolts
8mmx1.25
Main vaccume line
3/8
fuel rail studs
6mmx1.0
Garrett turbo bolts
8mmx1.25
Main vaccume line
3/8
If you're aiming this at turbos which it looks like you're doing then this should be in FI. By main vac source, you mean the brake booster.
throttle body heater line (for H2O cooled turbos) 5/16"
PCV hose 5/16 (I think)
Valvecover breather - 16mm
Radiator hose ID (both) - 30mm
length of fuel rail studs for K-series injectors - 30mm (minimum)
Sorry to bring this thread back but I have a tial wg and I was wondering what size vaccum line do I need for it (I tried using the line that came with my BOV but its way to small)
And just to clarify i need 30mm fuel rail studs for RSX injectors??
--Thanks
--Thanks
old97civic
Jul 9, 2015 12:19 PM
Touge
Jul 1, 2015 11:38 AM
Touge
May 20, 2015 10:53 PM
