To Many Wires Left Over
Old Apr 20, 2006
bajancivc's Avatar
bajancivc is an unknown quantity at this point
I am swaping out my 03lx d17a2 for an 05 d17a1. I am keeping my same trany. i got it all it but there are some connectors that have no whare to connect to. whats up with that? can anyone lend me a hand
Old Apr 20, 2006
ajhdragon's Avatar
7thgens official a$$hole
your going from a vtec engine to a non vtec engine, and there is less emissions stuff on the a1
Old Apr 20, 2006
bajancivc's Avatar
So I ust hook up all that i can hook up and dont worry about the left over stuff?
Old Apr 20, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
And there's no variable timing
I think its all one way plugs, so if there's unused plugs on the harness and no mating harness near it on the motor, then its most likely unused. You won't know until you fire it up and see what CELs it throws.
Old Apr 20, 2006
bajancivc's Avatar
Thanks for the info. hada typo in the first post. i am swaping a non vtec out for a vtec. the vtec engine has more wires then the non vetc. so i got left over wires.
Old Apr 20, 2006
Jap-Euro Fusion
Well now you have the reverse problem... you don't have too many wires, you have not enough in the harness.
You'll need to get those all hooked up for it to run right.
Old Apr 20, 2006
bajancivc's Avatar
Still a little lost on this. lets see if i can clear this up.
I have an 03 lx (non v-tec civic). I swaped that engine out with a 05 ex with v-tech. I kept my same trany. All i did was change the engine. It came with the wire harness attached. I connected all that i could. there are no more place to hook up any thing, but there are still like 5 wires that dont go to any thing. whats up with that?
Old Apr 20, 2006
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
^ thats your problem
d17a1- lx non vtec
d17a2- ex (cdn si) vtec
i didnt think that made much sense...why not just do a head swap?
Old Apr 20, 2006
bajancivc's Avatar
Okay you are no help. Cant swap a head on to a blow engine.
Old Apr 20, 2006
bajancivc's Avatar
I know someone on this site has done this swap, that can help
Is There Anyone That Can Help Me
Old Apr 20, 2006
xproductionz's Avatar
xproductionz is just really nicexproductionz is just really nicexproductionz is just really nicexproductionz is just really nice
the highly unusual....
heres is how i see it..
1.. if you are using the original engine harness from YOUR car you should end up with NOT HAVING ENOUGH wires cause the vtec and pressure sensor and what not.
2... now if you are using the ORIGINAL engine harness from the EX(vtec) that it came put of then you should have all wires and plugs plugged in.. if there is some hanging you missed something somewhere.... and dont ask us where it goes cause we cant tell you unless we physically look at your engine.......
Other than that there is no logical explanation of what you did wrong...
PS.... i hope u have a way of engaging vtec?
Old Apr 20, 2006
bajancivc's Avatar
I will check tomorrow, to see if i misted anything. But the old harness has less wires. O' and i got the ECU to engage my v-tec. just have to get my key reflashed.
Old Apr 21, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
rtfm j/k get a diagram of the wireing
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Poopies
Apr 20, 2017 11:36 PM
dpru
May 26, 2015 07:01 PM
pincookie1
May 4, 2015 12:22 PM
