what size turbo flange
Old Apr 4, 2006
D-RoK's Avatar
D-RoK is an unknown quantity at this point
i know its kinda a noob ? but what size flange would i need for a td04h turbo . i got a greddy manifold and turbo from a friend saying that it would fit but come to find out its for a d16 motor not a d17 . i plan on selling the manifold but keeping the turbo . also any info on the spec's of the turbo would be good. i plan on doing a nice setup. i know its going to be a few more months before i get all the stuff i need for the setup . i have the fuel system figured out i think . i'm going to probably run non- intercooled for a while . any cons to doing this . i searched non intercooled but really didnt find any useful info yet .(still looking). any other info you guys maybe want to shot my way i'm down to listen. thanks
Old Apr 4, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
well it sounds as if you dont really know much about turbo setups so just to let you know running without an intercooler isnt really the best idea, its not a step you should leave out, since your doing a custom kit that means your going to need either all custom piping or your going to have to order a pipe kit, which would include the intercooler piping...
check this out, if your going custom pick this up:
http://www.dezod.com/pd_dezod_motors...ooler_pipe.cfm
Old Apr 4, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
thats a mitsu turbo... you probably need a mitsu footed manifold for it. I don't know if its a standard T25 or not.
Old Apr 4, 2006
dezod's Avatar
7thgen Power Maker
Pretty sure that's T25 footed.
Old Apr 4, 2006
D-RoK's Avatar
i figured it was a mitsu turbo. i just figured i could run non- intercooled for a lil while til i get a lil more money. i've seen the non-intercooled kit for my sisters lancer and figured it would be bout the same . where do you think i'd be able to get a flange at for the turbo. i know on the d16 motors that they are customizing dsm manifolds to fit with out a lot of work . since its a mitsu turbo, you guys think i could go that route . if so i know someone with a talon that he is parting out and i could grab that and the side mount intercooler for cheap .my piping is not a problem my brother n law works at a muffler shop and can do the piping that i need .also i was reading that the rsx injectors fit. which model. base or type-s (if theres a differance). does anyone know if the fuel rail fits or not . i saw someone on the forum was going to try and see. whats a good but not money out the *** fuel pump to use with the return line. and as for the return line whats the best route to go with. just go along the brake lines . i know i got alot of questions but i figure its best to ask and get the info now(and get )then to not ask and maybe screw something up.
Old Apr 4, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Ebay sells turbo flanges.
Flange is a flange, if its made out of thick steel with smooth surfaces, you should be safe.
Also, PM Dezod, he may point you at the right direction.
68camerors
Sep 24, 2015 06:18 PM
