Blown?
I've got 50,000 miles on my engine, would a 55 shot Zex hurt it any farther if used properly? I was just lookin for anyone that has blown the block or had detonation in the d17's....preciate the responses...
I hope I offend you... Get mad
Originally Posted by Syke Fu
Long as you don't lean out and run premium gas, you should be good to go.
almost forgot BUY A WET KIT
u might want to add an air fuel gauge( the good one that have a wideband o2 sensor) for pre caut. i use to run nitrous in my talon and had mine hooked up in a way if my a/f went under a pre set setting that it would stop it from flowing( i had an bottle opener) also one more thing make sure after the first time u use it check ur plugs they tell u alot of info.
DONT PANIC
WHOA WHOA WHOA!!! IK16's??? That 2 steps hotter than stock! You want like an IK22 or IK24. 22's are 1 step colder than stock.
If you run a hotter plug, it will be more prone to detonate.
^^^ Haha yeah I was going to say something because IK16's didn't look right because I see everyone with turbo or nitrous having IK22's. Im not familiar with the IK plugs though because I use NGK coppers and wasn't sure
Yeah, no reason not to get a wet kit. Install is a little harder, but not by a great margin. Even with the wet kit you are still gonna wear your motor though. I was thinking about getting it a while back but then realized it costs a good amount in the long run, cause you need extra stuff. But then again, you could spend like 500 bucks for 50whp on a used NX kit, now I gotta becareful...Its comin back
DONT PANIC
Originally Posted by HiVtec
NOS Wet 50 Shot, and I had to much detonation with the 50 shot I end up blowing the IM with 75.
grammar?
i was doing the 50 but and the stuff go with the boom and the things that splash and crinkle then poof with smoke with 75.
^^^ That is what your post looks like to me.
If you blew up your intake manifold with nitrous, then you either #1. installed something wrong, #2. ran the wrong jets and went lean, or #3. dont know how to drive and pegged the limiter with the nitrous on for like 10 minutes.
turboengnr
grammar?
What grammar shi(*))*?
O I get it you are in kinder, I need to explain it step by step.
DONT PANIC
Originally Posted by dictionary.com
gram·mar
Noun
1. The study of how words and their component parts combine to form sentences.
2. The study of structural relationships in language or in a language, sometimes including pronunciation, meaning, and linguistic history.
3. The system of inflections, syntax, and word formation of a language.
4.The system of rules implicit in a language, viewed as a mechanism for generating all sentences possible in that language.
5. A normative or prescriptive set of rules setting forth the current standard of usage for pedagogical or reference purposes.
Noun
juicetayne
Sep 30, 2015 11:02 AM
raymondxcho
Sep 29, 2015 09:00 PM
Mc7602
Sep 17, 2015 02:01 PM
tooly145
Sep 5, 2015 01:05 AM
