boosted, tuned and dyno #'s
Old Mar 17, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
so ya im finaly finished my car, got the sf kit with sf fuel system.
i changed over to a steel briaded oil return line and got some exhaust work done so iv got 2.5" downpipe for about 2 feet, then 2 1/4" magnaflow.
i got the car on the dyno and we played around with the fuel pressure until we got the best a/f (about 12:1) and the numbers are 165 whp, 150 wtq @ 5-5.5 psi
planning on getting emanage and all harnesses pretty soon.
Old Mar 17, 2006
C2i0v0i1C's Avatar
SuperMODrizd
sounds about right
Old Mar 17, 2006
dezod's Avatar
7thgen Power Maker
Good for you.
Post up your graphs.
Old Mar 17, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Good #'s!
Is it t3 or t3/4 turbo?
again,
- without dyno graph!
Old Mar 17, 2006
dezod's Avatar
7thgen Power Maker
Originally Posted by 03-Acura-1.7-EL
Good #'s!
again,
My guess, a T3 60 trim
Old Mar 17, 2006
Karumba's Avatar
Boredom causes changes ;)
Glad to hear it is finally all done and running good Jamie. I'm sure you'll have fun with it this summer
Old Mar 17, 2006
ya dezods got it right super 60.
im gonna try and scan the dyno sheet but i think my scanners a bit messed up. anyways thanx for the feedback.
ya you know it. so whens the first meet??
Last edited by jamie_civic; Mar 17, 2006 at 02:20 PM. Reason: Automerged Doublepost
Old Mar 17, 2006
Karumba's Avatar
When it is actually spring/summer perhaps
Don't worry, if one is organized, I would be sure to tell all that I know
Though if you want to pop into the MR's attempt to revive Lafleur's that first Thursday in April perhaps I'd be around Guaranteed I wouldn't be in full summer mode though
Old Mar 17, 2006
jknudsen's Avatar
MAVS FAN 4EVER
jknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the rough
looks great man, keep it up
Old Mar 17, 2006
turboengnr's Avatar
DONT PANIC
seems about right. Which SF fuel system is it? I am guessing the newer billet aluminum version, right?
In that case, be very very careful when you turn up the boost. The boost-reference pressure regulator does not work at the intended rate. Instead of a 12:1 pressure increase ratio, it has a 7:1 increase ratio. It is fine for the first few pounds of boost, but as you increase the boost more and more, you will get leaner and leaner.
Old Mar 18, 2006
well i wouldnt increase the boost and play around with it unless i was on the dyno and using a wideband (which my tuner installs in the downpipe)
but i dont plan to go more than the 5.5 im at right now, when i do it will be with emanage, exedy clutch and a wideband in the car at all times.
oh and ya its the aluminum version.
Old Mar 18, 2006
Michalo187's Avatar
Abortion Survivor
good job! how does it feel and how are you liking the sf kit
Old Mar 19, 2006
feels great, i kept up very close with a sr20 (sylvia)...the guy does a 13.8
and ya the sf kit is very good since i put those numbers down with a shitty fuel setup and at 5.5 psi.
Old Mar 20, 2006
turboengnr's Avatar
DONT PANIC
just think of how much power you will make with a real engine management. You will notice a big difference.
Other than that, the kit is made quite well.
Old Mar 20, 2006
civic01vtec's Avatar
Glad you are liking it. Boost is very addicting and can rob your bank acct if you are not careful
Old Mar 20, 2006
ya i cant wait till i get the emanage and up the boost to maybe 7 psi...
and ya im fully aware of how it can rob the bank account, already has and is still. damn this ***** crazy expensive.
Old Mar 20, 2006
dipset82's Avatar
dipset82 is an unknown quantity at this point
You can say that about 10 more times man!! I finally have everything finished on my 05VP i have the TSI kit T28bb I don't have any dyno runs but i know my car feels a helluva lot better than just intake and exhaust right now i'm set 8 psi it runs strong no problems yet. Good Luck man can't wait 2 c what #'s u do w/emanage!!
Old Mar 21, 2006
turboengnr's Avatar
DONT PANIC
did you tune it with a wideband? Because tuning can make you gain a ton of power.
Old Mar 21, 2006
ya ofcourse he used a wideband...also it was in the downpipe not in the muffler tip.
Old Mar 22, 2006
turboengnr's Avatar
DONT PANIC
ok. just making sure.
bowie
Jan 21, 2018 09:29 PM
UltraHDGames
Jun 8, 2016 05:16 PM
C-Hamm
Sep 28, 2015 10:31 PM
Zedoc
Engine Swaps
Sep 12, 2015 04:27 PM
99BoostedSi
Sep 7, 2015 04:49 PM
