450 Dsm
Old Mar 13, 2006
dipset82's Avatar
dipset82 is an unknown quantity at this point
450 Dsm
Does anybody know if the 450 DSM injectors will work on a boosted 05 VP? I have t28bb. Not tryin to put down good numbers just tryin 2 run 6-9lbs.
Old Mar 13, 2006
turboengnr's Avatar
DONT PANIC
if they are the same physical size as the SRT4 injectors with the same o-ring diameter, then you should be able to make them work.
Other than that, i guess i am no help. I havent tried the DSM ones on a 7thgen.
Balkos
Sep 11, 2015 11:39 PM
