Ok time for some problem fixing help (Edited with some cool pics)....
Old Mar 3, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
The test fit day is always full of surprises.
the first one, the header came off with out a fight.
That was the only good thing the whole day.....
Question 1: Whats the criticality of the plate on the drivers side of the exhaust tunnel next to the AC compressor? Can that be ditched? I can't see it blocking much heat.
Next little pile of issues is the way the turbo fits. First of all, it hits the rad. core support. Nothing a BFH can't fix.
Second, there's a plug for something I didn't bother to trace in the way of the compressor inlet, Looks easily movable from the bracket though.
Third, bigger problem, see second pic, Hot side clearance to the AC is non existent. Open for suggestions here. I just don't see how the DP is going to clear that, even if I curl it back under the turbo immediately.
Fourth is how low the compressor outlet is. Its about 1" above the motor mount, I'm not seeing a way to fit a pipe though there without losing a fan. Need the insight on this one.
Moving a little lower... went to set up the oil pan.... umm its not flat. There goes all hope of a bolt in fitting staying sealed. Gotta find someone who can TIG and make a friend.
Good news is I made the line (really what I did was splice 2 fittings together with a small piece of stainless hose )
Oil feed setup got cut out and added. I put it in the cooler return line with a bunch of AN fittings since believe it or not, no one makes a mid line splice fitting for SS lines. So I needed 2 hose ends, a male to male union and the fitting with the T port on it. Retarded.
Anyways, so yeah. I knew it wasn't gonna be a cake walk, but I was hoping something would go my way...... nope. Insult to injury I put the header back on and the gasket would seal. $26 later, I had myself a new donut gasket for the downpipe so I can drive around without smoking up a storm for the next few weeks.
Old Mar 3, 2006
eye_see_you's Avatar
let the devil out
that looks clean man cn't wait to see how it turns out
Old Mar 3, 2006
tfnaaf's Avatar
BLDNPSI Mod
#1 yes i removed that plate on mine
#2 not sure what plug your talking about?
#3 curl it torwards the engine and under turbo( see my pictures) BTW i covered my AC line with some heat reflective material
#4 i used a 90degree elbow and cleared fine on mine .....shrug maybe try clocking the compressor some?
Looking good, keep up the good work!
Old Mar 3, 2006
Jap-Euro Fusion
The plug was the O2 sensor... you can see the plug I was talking about in the first picture. There's a couple intermediate fasteners that can be removed and that wire can be re-routed elsewhere.
Old Mar 3, 2006
cubanmike26's Avatar
That's looking very nice
Old Mar 4, 2006
andyman97's Avatar
Turbo Guru
Yeah man, remove the ac plate and the o2 harness from the plate, just zip tie it down elsewhere.
As far as the downpipe, that's always been tricky getting them to fit.
For the compressor inlet, I assume you're talking about the filter pipe. Gotta get creative there and get some bends if it doesn't fit. That's an easy fix.
Old Mar 4, 2006
Jap-Euro Fusion
AH! Ha Ha! The boost gauge works! Something went my way this weekend. Only problem is it still stops at 0.
Old Mar 4, 2006
skipbarber's Avatar
^i have that problem too..amongst others we suck boiler
i test fitted my brand new dezod EL manifold today..luckily it looks like everything will go smooth with that. While we were at it we installed my exhuast today...not so good news.
#1 - lost my front sway bar...kinda interesting, but i think it'll get old pretty fast, i have nice oversteer but the car simply DIVES into every turn.
#2 - the EX header i used was so rusted out, one of the threaded ends stripped out, so i ended up boring out the hole and using a bolt and nut...which introduced a nice leak.
#3 - the muffler rattles with my progress rear sway bar...
Old Mar 5, 2006
Jap-Euro Fusion
1. pick up an ex sway bar
2. who cares you got a week until the turbo goes in. I have a spare (new) donut gasket if you want to try that.
3. shorter exhaust hangers?
Old Mar 5, 2006
skipbarber's Avatar
yes, i was thinking an ex front...my friends are trying to get me to go with the progress...i kinda like excessive over steer, what year was the ex front sway the thinnest?
im using a brand new donut. i just need to cut off the existing welded nut and replace it, and i cant get shorter hangers because the muffler is already really close to the bumper..
Old Mar 5, 2006
Jap-Euro Fusion
03+ is a 16 thats the thinnest.
Old Mar 6, 2006
Jap-Euro Fusion
My new Rolex
The command center (minus the W/B AF which is going elsewhere)
For those of you who have never seen the inside of a turbo, here you go. There's really not much to it.... its a snazzy hair dryer.... but wear gloves and don't touch anything if you open one up.
Old Mar 6, 2006
Cptn. Slow's Avatar
Formerly efil on evol on
Cptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura aboutCptn. Slow has a spectacular aura about
good luck working out those issues. Hopefully you will continue to only run into small problems
Old Mar 6, 2006
C2i0v0i1C's Avatar
SuperMODrizd
i didnt read all that but do i see a oil return that is 100% fittings
Old Mar 6, 2006
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
Sweet gauges, I have Defi gauges aswell. Which turbo is that again, it's a GT28RS right.
Old Mar 6, 2006
tfnaaf's Avatar
BLDNPSI Mod
its a GT28R
Old Mar 6, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Boiler, what gauge is it on the right of boostmeter?
Old Mar 7, 2006
Jap-Euro Fusion
Its a Defi OLED display.... it shows everything else besides boost (oil T and P, water temp, speed, and if I can ever figure out how to make it read the dizzyless ignition, it'll read and warn for RPMs as well)
Old Mar 7, 2006
That was a stupid question on my part. The GT28RS has a different compressor housing. Can't wait to see the car done, your going to love boost.
Old Mar 7, 2006
HyaBoosta's Avatar
yeah looks like a tight squeeze for the DP. gonna have to **** it under down at a 90 and at an angle. not the best for flow. I think a new manifold is gonna be best. alot of mani's **** the turbo inward some to give more room for the dp to clear that line.
Old Mar 10, 2006
cleancivic 05's Avatar
cleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trustedcleancivic 05 should not be trusted
how much does the defi dis cost and what do u need to get with it and what do u mean about dizzyless ing what do u need to get it to work. just asking some ? i was looking at that gauge for my car.
Old Mar 10, 2006
Jap-Euro Fusion
-About 1000 bucks what you need depends on what you buy. The only thing you must have is the control unit.
-the computer can't read the tach signal because its looking for ignition pulses and its not getting what it wants
Old Mar 10, 2006
dezod's Avatar
7thgen Power Maker
Lookin good. Keep the progress comin
Old Mar 10, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Old Mar 10, 2006
Jap-Euro Fusion
Originally Posted by 02fpcivic
Yeah I know, I know.....
Old Mar 11, 2006
02fpcivic's Avatar
hah, I hadta do it.
Old Mar 11, 2006
dezod's Avatar
7thgen Power Maker
Hey any progress while attempting to boost on your own is good progress. Now you are realizing all of the fun involved in creating a system. Crash course 101.
Now imagine this with your end product that has to be replicated....fixtures need to be utilized. Cost effective means of production with flow, performance and cost in mind..........welcome to our world.
Old Mar 11, 2006
HonCivX02's Avatar
HonCivX02 is an unknown quantity at this point
The setup is coming out good dude, looks sweet. And that gaudge is f*ckin sweet!
Old Mar 11, 2006
Jap-Euro Fusion
Well its an inside thing.... I was supposed to be up at his place this weekend making stuff fit... and it kinda got pushed back.
Old Mar 11, 2006
mrDFWmechanic's Avatar
everything is lookin good so far
mikemc422
Aug 9, 2018 05:41 PM
dosmastr
May 5, 2015 12:19 PM
Tommy Cohen
May 1, 2015 02:02 PM
ImmortalEX
Nov 8, 2001 09:52 PM
