what next?
what next?
Hey guys i've been with this place for a little while and i wanted to know what i should do next to increase gains. I dyno'd at like 215 whp with my t28bb and i wanted to know what i should do next, if anything, to the engine to increase gains...for instance throttle body, intake manifold, forged internals...anything would be of assistance at this point. thanks in advance
Talk with Dezod, He can hook you up with his pistons and he can hook you up with some rods. You also wanna sleeve the block. The sleeves will cost you around 235. But they cost probably 1 grand and higher to install. If you just want a little more power get the Crower Stage 2 turbo cam, valvesprings and retainers and you might as well change the valves. You could also have some head work done to your car like port and polish. Bored out throttle body. There is so much you could do.
Drunken Master-7thgen Ninja
blockgaurd, higher rating bolts to hold down the cylinder head and cover. turbo cam, with springs and retainers, bigger fuel and oil pump,
EDIT: you don't HAVE to sleeve your block if you do it right
hold on ill find it for you...
there ya go
http://honda-tech.com/zerothread?id=1496464
right under the dyno graph. it says stock sleeves
there ya go
yeah install isnt the problem...my dad is a certified mechanic and i've been "wrenching" with him since i was old enough to change oil....so yeah we can do a majority of the work....thanks for the advice i'll talk to dezod. Does he offer the sleeves?
o and my last question...i have the passion for the car...however is this platform worth the work/$$....i mean what possibly can i see in returns....as i kinda mentioned i've been out of the game for a little bit due to school which is why i dont know whats out there anymore for the d17...and yeah i wanted to know if anyone has gone all out and what they have seen at the dyno and at the track? thanks for al the help guys
I am not sure if he offers the sleeves, He might if not pm me i have the website. You might always want to upgrade to the Aem Ems its a stand alone computer, It cost quite a bit of money but it helps out a lot because you have so many tuning possibilities and that computer understands the boost. I would get that before i started building up the motor. Dezod can get you that computer
Andyman has had the best outcome so far. No one has ever hit 300whp but andyman plans to be the first, He ran 13.8 @ 104 and he got 247 whp and 212 wtq @ 13psi. Also C2i0v0i1c got 245 whp and 207 tq @ 14 psi Those are pretty much the best numbers as of now. Andyman is all completely stock motor. C2i0v0i1c has his motor built.
Originally Posted by Michalo187
^^^ Are you sure about that dude? I thought no one had ever done it?
he was banned for ripping people off on the site. anyway, idk i can't find his setup page. it was one page that listed everything that was done. everything.
how did you find it?
Wish I had a Turbo
