Some info to save some tuning headaches
Old Feb 11, 2006
speedster's Avatar
speedster is an unknown quantity at this point
I thought I'd share my final results on my jet sizes on my 50 shot NOS brand wet kit. According to the AEM wideband a/f ratio gauge, I'm running right at 12.5:1 under all motor WOT. When spraying (starting at 4400 rpm's) I'm running 13:1. At 6200 rpm's (right at when the systems turns off by means of the window switch) I'm running 12.1:1. This is at 950 psi bottle pressure. I consider this to be as close as I can get according to the recommended 12.5:1 when spraying. My final jet sizes used where .020 fuel and .030 nitrous. So if anybody is considering bolting up a 50 shot and is worried about getting it just right, well, here you go
Old Feb 11, 2006
diskreet's Avatar
cool post, good info for anyone who is thinking about doing this.
Old Feb 11, 2006
puidokas's Avatar
puidokas is an unknown quantity at this point
will the results be the same on all 7th gens though?
Old Feb 11, 2006
speedster's Avatar
Well, I guess I should've told my car type. I have an 02 LX coupe 5-speed. This is a non-vtec engine. I can't say this would be the same on a vtec, but I'd say you'll be "good to go " with this on LX models.
Old Feb 12, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
It prolly depends on air intake temps too. however if the jets he suggests make the car run a lil richer than what the NOS suggested jets are, you will be safer for running them. No harm in running a lil bit fatter. Less chance of detonation is a good thing.
Old Feb 12, 2006
speedster's Avatar
The jets I suggest make it run a little leaner than the recommended jets from NOS. They say run a 22 fuel and a 30 nitrous for a 50 shot. This combo made it run around 11:1 a/f ratio. Although the instructions kinda contradict theirselves. It says the recommended jets are for a 43 psi fuel system. But then it says in the fine tuning section to run between .019-.021 for a .030 nitrous jet with 40 psi fuel pressure. I found this to be better according to the wideband. I thought about going the other way by going richer on the nitrous jet. Say a .022 fuel and .032 nitrous. This would be the same as the .020/.030 combo, just a little more power. I didn't want to overpower the engine with more than it could handle, so I lowered the fuel jet instead.
Old Feb 12, 2006
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
yeah i was running a .19 fuel and a .29 nitrous. simply because i couldnt find a .30 lol. anyway i really liked how the setup ran on my 04 lx coupe 5 speed.
great thread though
Misfit2613
Jul 30, 2015 09:49 AM
krazykoncepts
Jul 14, 2015 01:55 PM
Pwelsh
Engine start problems
Jul 9, 2015 04:15 PM
