Is there an ideal place to stick the e-manage box?
Old Jan 25, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Its physically larger than I thought it was. I was going to bolt it to the back of the glove box but I think its too big. I know a lot of you guys stick em under the seat, do any of you worry about dirt or **** getting into the box under there (dirty shoes, etc)? I just want to make sure its completely out of view. I had thoughts of mounting it under the center console between the shifter and e-brake, but then the box is pretty inaccessible if you need to work on it and I'm not sure if it'll fit there either.
Range limit from the ECU is about 2 or so feet... thats the length of Dezod's harness.
Old Jan 25, 2006
red_sun's Avatar
Boost is so good make you wanna slap ya mamma
red_sun is on a distinguished road
I put it in the space under the steering wheel. I velcroed it in so it wouldn’t slide around but when I need to tune it's easy to pull it out. I don’t know if you have enough wire to reach there but if it does its easy to access and it's protected from dirt, water.
Old Jan 25, 2006
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
under the seat works fine too. some people have put it IN the glove box
Old Jan 25, 2006
HyaBoosta's Avatar
mines in the glove box. does just fine
Old Jan 25, 2006
tfnaaf's Avatar
BLDNPSI Mod
under the passenger seat worked for me
Old Jan 26, 2006
dezod's Avatar
7thgen Power Maker
My old D17
Old Jan 26, 2006
C2i0v0i1C's Avatar
SuperMODrizd
under the pass seat. zip tied around a plate under the carpet then wires are fed under the passenger carpet to the corresponding places
Old Jan 26, 2006
jamie_civic's Avatar
jamie_civic is an unknown quantity at this point
under the seat should be fine, alot of cars have their ecu under the pass. seat.
Old Jan 26, 2006
eye_see_you's Avatar
let the devil out
attached to the bottom of the seat cushin itself with zip ties
Old Jan 26, 2006
i think glove box is your only option with pnp harness.
Old Jan 26, 2006
skipbarber's Avatar
^ i thought about that, but it makes it harder to see the indicator lights. I screwed it down to the floor directly under the seat. Sliding the seat forward all the way only exposes half of the unit. I think it's pretty accessible and still practically invisible.
Old Jan 26, 2006
Jap-Euro Fusion
Originally Posted by dezod
My old D17
I'd do that, but I actually use the glove box for stuff. I wanted to stick it on the back side, but it doesn't seem to fit. I'll come up with something. Up in the center console or something is possible. There's lots of room under the dash.
I'll figure something out. How much cooling does it need?
Old Jan 26, 2006
dezod's Avatar
7thgen Power Maker
I still used the glove......
Old Jan 26, 2006
tfnaaf's Avatar
BLDNPSI Mod
I made a bracket thats bolted to the bottom then attached to the floor...
Old Jan 26, 2006
skipbarber's Avatar
^thats almost what i did, I like it there, it's out of the way and still very accessible.
Old Jan 26, 2006
asian relic's Avatar
asian relic has a little shameless behaviour in the past
Any other pics of where the emanage is? B/c I'm going to need to figure it out too b/c I'm going to be working on mine this summer.
JohnnyBxo
Nov 12, 2015 03:04 PM
Jul 12, 2015 11:54 AM
fordover
Jul 11, 2015 09:10 PM
