My simple intended setup...
Old Jan 24, 2006
snooze2's Avatar
snooze2 is an unknown quantity at this point
I m lookin for a drivable ride that allows me to overtake with ease n some occasional traffic light sprints if required (running at 7psi at most!!)... not going for low timings in 1/4 runs or high hp... thinking of putting the following into my ride, can the experts out there give me ur kind comments... Thanks...
Setup as follows...
> T25 with wastegate
> BOV
> Customised piping as necessary
> NO intercooler
> RSX injectors
> Emanage with necessary harness.
I m not based in US, so cant really get my hands on the wonderful Dezod or TSI kits... Average temperature is like near 30deg C over my side... Any kind comments will b great!! Thanks...
Old Jan 24, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
ummmm I wouldn't be running in 90 degree weather without an intercooler. Its just asking for it.
At 7 psi, you're probably looking at 200F intake temps.
You can pick up generic fit intercoolers for not a whole lot of money.
Old Jan 24, 2006
snooze2's Avatar
Thanks for your input... i m lookin at having a simple setup with low boost, and the thought of having an intercooler is adding to the cost and pipe routing complexity, though having a small S14/5 side-mounted ITC may/will solve the problem...
In Singapore, it is illegal to have a turbo kit for a NA ride, so having that stealth exterior is also 1 of the top priority... Any other views??
Old Jan 24, 2006
PrecisnTec's Avatar
PC Tech / Autocrosser
PrecisnTec will become famous soon enoughPrecisnTec will become famous soon enough
Why not use a mitsubishi eclipse side mount intercooler? As far as keeping it stealth, you may also want to use a reciculation valve or however it's referred to. in other words, don't use an atmospheric bov, have it dump the charge to the turbo inlet tube to keep spool up between shifts. Both b.o.v. and recirculation have some noise to them, but the recirculation will be beneficial for keeping spool up and keep the stealth theme.
Othewise I'm looking at the same setup myself. I probably will be looking / hoping to have the boost set for at least 5 - 6 psi. Which for a novice should be more than enough for now.
Old Jan 24, 2006
Jap-Euro Fusion
PM me, I'll show you my sneaky rig.... but I'm not letting the cat out of the bag to the rest of you yet
Old Jan 24, 2006
7psi is not low boost
Old Jan 27, 2006
Alex1's Avatar
Just get a 1st gen DSM sidemount from an eclipse and 3 pipes is all you will need. It's cheap, like $20-$30 US and good enough for 7psi.
Old Jan 30, 2006
TheSmuggler's Avatar
Try like 3-4 psi lol
Old Jan 30, 2006
Alex1's Avatar
That intercooler withstands 14-15 psi so why not 7 psi?
Old Jan 30, 2006
I meant 3-4 psi is low boost; Just agreeing with Gear.
Old Jan 30, 2006
Alex1's Avatar
Oh okay, I'm with you then.
Old Jan 31, 2006
snooze2's Avatar
Thanks for all the wonderful comments n inputs bros...
Mabbe I shld reduce my 'intended' boost to abt 4psi...
I m mre inclined towards this kinda setup (different engine though)... seems okie as its built for runnin in the same climate as mine...
http://asia.vtec.net/beystock/Civic/art7/index.html
Any comments??
Old Jan 31, 2006
Alex1's Avatar
Any comments??
You seem to be going towards the same "no intercooler" direction so I think that you should just try it and let us know how it goes. Hey, if that guy can do it, then why can't you, right? I for one, am interested in the results. Good Luck!
Old Jan 31, 2006
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
Any comments??
why would you go to all of the trouble of a turbo kit for 4 psi? That'll net you around 30HP. why not just get a 25 shot? It'd be WAY cheaper.
Old Jan 31, 2006
tarheel365's Avatar
tarheel365 is an unknown quantity at this point
eh...well i guess if he changes his mind he can fab up some pipes and add an IC.
i don't really kno much about nitrous but you'd have to fill it up eventually. and in some states its illegal to have a nitrous set up.
Old Jan 31, 2006
thiscrackerntam's Avatar
thiscrackerntam will become famous soon enoughthiscrackerntam will become famous soon enough
you can forget about a side mount IC...it'll never work...
Old Jan 31, 2006
Jap-Euro Fusion
And why the hell not?
Old Jan 31, 2006
jknudsen's Avatar
MAVS FAN 4EVER
jknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the roughjknudsen is a jewel in the rough
Not sure if its legal or not, but if you get caught they might cane your ***!
Old Jan 31, 2006
find me a side mount IC thats small enough to fit inside the stock bumper of a 7th gen without hackin it all to hell and I'll say it works....ok?
Old Jan 31, 2006
Jap-Euro Fusion
Well, I don't know why it needs to fit in the bumper, but ok.
And yes, it works quite well... the magic of pressure differentials and air ducts.
Custom fab shops do marvelous things.
Old Jan 31, 2006
Its better to have it in the bumper thats why most car manufacturers have always placed them in the front bumper in the past. Yes you might have some air ducts in there but its not going to cool as well as one would if it were in the front bumper. Is it going to cool well enough? It probably will, but not as good and I personally wouldnt put one in that spot, but thats just me...it does look nice though....
edit: damn its been a while since I owned a 7th gen... I just realized you had to relocate your battery in order to do that too... that blows...
Old Jan 31, 2006
Uh oh time to make a duct onto that bad boy
Old Jan 31, 2006
Jap-Euro Fusion
I'm not worried. I'm one smart cookie. There's enough high pressure around there with a couple of louvers in the splash guards and a pair of NACA ducts, plenty of air will go through there. That core is good for almost 300 HP, I'm going to be pushing about half that through there.
Old Jan 31, 2006
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
thats sexual.. ^
Old Jan 31, 2006
SLO REX's Avatar
250+ awhp Stage 2
Please do!
Old Jan 31, 2006
^^no where near as much pressure as it would receive being in the bumper and now you have hot radiator air/underhood temps to contend with now but like I said before.....to each their own
Old Jan 31, 2006
Jap-Euro Fusion
Park on downtown city streets somewhere for a while and you'll see why I don't want expensive and fairly delicate hardware critical to the car's function in the front bumper. People who can't park, attempt to park by feel. So I'm keeping it inside. Its not enough horsepower to need a 20x12 core. Hot radiator air? Shrouding will keep the radiator crossflow off of it. Thats a pretty easy fix. Put the intercooler in front and you have hot water to deal with. It goes both ways. Trade one for the other.
There's a reason for everything. I know it isn't ideal, but compromises get made, but without huge power in mind, trading the life span and durability of the intercooler for a couple degrees is a worthwhile move for the time being. Situation changes, intercoolers are pretty easy to get, I'll look into something else when the time comes to turn up the boost.
Old Feb 1, 2006
snooze2's Avatar
Smile
Umm... as 1 of the bros had mentioned... this setup offers a gd route for upgradin if required... Gettin a NOS kit is out as its hard 2 get refill over here.
Heheh... i m nt greedy anyway... 30hp shld b gd enuff 4 better drivability, as illustrated by the dyno grph...
Old Feb 1, 2006
snooze2's Avatar
Thumbs up
The Cat is outta the bag!!!
Old Feb 1, 2006
snooze2's Avatar
Red face
Spank me baby!! Spank me!!
Haha... we dont spank every1's little *** for everything here...
