watchu think about this turbo setup?
Old Jan 19, 2006
ill02civic's Avatar
ill02civic will become famous soon enoughill02civic will become famous soon enough
-garrett t25 turbo w/ wastegate
-cast exhaust manifold
-chrome heatshild
-downpipe w/ gasket
-map unit (black box)
-tsi blow off valve (bov)
-tsi high flow front-mount intercooler
-polished aluminum intercooler piping
-SS braided lines for water cooling
-SS braided lines for oiling
-return hose and fittings for oil to pan
-all hoses & clamps
-all necessary hardware & fittings
-fuel system option which includes (2 injectors & interface block),(tsi ijection control unit w/ turbo timer), and injector control system settings..
Old Jan 19, 2006
ajhdragon's Avatar
7thgens official a$$hole
its cool for low boost like from 7-10psi. probably gonan want to get a new waste gate, just from personal experience the ones that come with the t25 aren't all that great i think their set at 5.85?
Old Jan 20, 2006
ill02civic's Avatar
oh iight thank for the info ...... u had this kit on ur civic ? im not the type to beat up cars..naimean..this is my project / show car .... but give me more info about this kit ..
Old Jan 20, 2006
ajhdragon's Avatar
i have a similar setup on my car.
Old Jan 20, 2006
eye_see_you's Avatar
let the devil out
your wrong there.. on psi.. I was running 13psi daily on the TSI kit and 16 psi at the track it just tops out there being that the most it can handle is 20psi with the t24bb turbo. Yes its internally wastegated but the tsi injection control module allows the changes . Its not a bad setup for a little more power to the wheels but overall better fuel management would be recommended from my experience.
Old Jan 20, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
I have TSI extreme w/t25 and run 8-9psi daly. For the fuel I have 2 extra injectors (great little box!) and missing link for map sensor. Sor some reason tsi map black box did not want to work for me, so I got missing link instead - I think its better then black box.
I like it.
Problem is tracsion, when went wheels spin through 1/2/3 gears...
Old Jan 20, 2006
ill02civic's Avatar
wsup
Thanks For The Feedback People ...so What Is A Good Psi To Set This Up In For A Daily Drivin ? And Don't Want To Mess It Up Rightaway ..and How Much Horse Would I Be Putting ..?
Old Jan 20, 2006
there was plenty said about these tsi kits, just try searching f/i forums, you'll be abe to get more info then we could comprehend in this little thread..
Old Jan 21, 2006
exturbo6's Avatar
I like it.
you know all those probems i had with the tsi turbo kit..i wonder since you said the black box never worked for you that thats what my problem was..i didnt have miossing link...mmmm i guess ill never know...dam that sucks!
Old Jan 21, 2006
turboengnr's Avatar
DONT PANIC
This isnt exactly a "show car" turbo system......
Old Jan 21, 2006
Show car turbo systems usualy look good, but give little.
Old Jan 21, 2006
let the devil out
the TSI kit itself is a great kit once tuned and setup properly I was one of those few that with a built automatic returned really impressive gains from it. Its pitfall is the fuel management thats about it and the universal BOV that is used normally comes on DSM's from the factory.
Old Jan 22, 2006
turboengnr's Avatar
DONT PANIC
The show cars ive done gave a whole lot. They were all a hell of a lot faster than my civic was.
Old Jan 22, 2006
yourinmyw0rld's Avatar
Some of them are not even hook up
Old Jan 22, 2006
BudDyLeEBoOsteD's Avatar
BudDyLeEBoOsteD has a little shameless behaviour in the past
Thats the TSI kit that you can buy of TurboKits.com I had that turbo kit in my car and it ran great,,,,, but after puttin down some extra $$$$$ on fuel management $hit. it got pretty expensive. I didnt ge the 2 Injectors with the Interface block, I had the S-AFC sent to me. Thats probably why too.. But i had to get a return line for fuel, A.F.P regulator and a **** load of otha stuff... I was like you once!.. Thinkin i had a show car and maybe spice it up with a turbo ya knw>? well a year after i had the turbo in the car.. my oil return like had a leak, next thing you knw my car was on fire.........
and that about SUMS up for my TSI Kit experience..... lol
Hope you get ready to go through some headaches my friend!...
Good Luck!
Old Jan 22, 2006
Hope this doesnt Discoruge you!!!!
Just I had **** of luck.. plus when i did it, the kit was still kinda new, so not alot of ppl had it yet!>. so it was all about Trial and error...
Old Jan 22, 2006
Thats was said in a funny..lol
I personaly like TSI kit. Its simple and give a lot of fun for the buck.
Old Jan 22, 2006
ill02civic's Avatar
yeah man .. that leak that somebody had ..his turbo prolly wasn't put in by a proffessional ..or he prolly messed around w/ the wires and got it loose ....that doesn't encourage me of not buyin it ..kuz i arealdy bought today ... comin in friday ....gggyeahhh.... what psi should i set this on for my stock d17 engine ..?
Old Jan 22, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Its got an internal wastegate, its already set. Just leave it there until you can tune it.
Old Jan 22, 2006
let the devil out
true that its internally gated but the TSI injection control module is what let me run my boost up to 13psi daily and 16 on the track but it really does need better fuel mangement thats the only down fall of this budget turbo kit
Old Jan 22, 2006
Matulin407's Avatar
Matulin407 is an unknown quantity at this point
no means to jack thread.. but im debating buying this kit, and i thought tuning is a must before u drive. Are yah saying that u can drive it around untuned? cuz if i do get it put on i may not be able to get it tuned for a few days, and my work is 30+ miles away from home. Would it be okay to drive it to and from work untuned? (im trying to buy a SF kit from JEFF but he is freakin AWOL!) so i may go tsi.
Old Jan 22, 2006
tfnaaf's Avatar
BLDNPSI Mod
NO
Old Jan 22, 2006
Matulin407's Avatar
Yay!
Old Jan 22, 2006
ruffryde009's Avatar
ruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to allruffryde009 is a name known to all
awesome new TSI Thread! ... fresh info
I will be installing mine soon, Ill keep you guys updated
Old Jan 22, 2006
supertuner's Avatar
supertuner is an unknown quantity at this point
sounds like a nice setup, very streetable
Old Jan 23, 2006
OH it was set profesionally, you're right though I did mess with the wires in some sort of way. and HEY accidents happen.. This was about a year ago.., and to tell you the truth.. It was the best thing that ever happend to me.. I miss my car like a mother fuc*** but the headaches that i had with that car when it was turbo'd was fuc*** pissin the fuc* outta me ... YOUR ALL HAPPY NOW, but wait till you get it and then your FUEL starts acting up.. wait till you get to the tunnin part.. OOH buddy you got it commin, hopefully you got money for dyno's because ill let you knw right now, if you plan in gettin your car turbo charged and not tunnin in it as its supposed to be.. Youll be either runnin RICH as hell when your car is on IDLE but then LEAN As F^%$ when boostin or vice/versa.. Hopefully it has been a bit more mastered now since then. back when i had it, it was only few that had the car runnin right, and then they still had issues. With that car catching on fire, Insurance payd it off.I used that money for a down payment on a car that was meant to be turbo'd. 04 Suburu STI.... BUt yea d00d... Hopefully you knw what you;re doing. Cuz you dont want to warp your engine apart by not having it done right. Theres plenty of guyz here that can give ya advice.. Such as civic01vtec, TTnaaf,Havok2k1 etc........
Good Luck
Old Jan 23, 2006
Good Luck
Holly crap!
I've seen pics of your car and it was a very nice baby.
Sorry you had to speak about it again....
Unfortunately this can happen to anyone and you lucky didnt get injured. Its good that everything worked out fine at the end.
For mild boost settings 6-10psi this fuel set up will be just allright. Tuning with TSI 2 injectors unit its not that complicated if its done on a dyno. If A/F goes off desired setting, this is probubly due to outside weather change. Turbos are sensitive to temperature change.
Its advised to make separate dyno tunes for winter and summer driving...(for each season is the best thought)
Old Jan 23, 2006
Holly crap!
yup*
Old Jan 23, 2006
Oh thanks about the pics of my car.
Old Jan 24, 2006
ill02civic's Avatar
yah true accidents happen ... but let me see some pics of your civic before it got burnt ...and after ...
Good Luck
