H22 + boost = good, or trouble?
Old Jan 17, 2006
Boods's Avatar
Boods is an unknown quantity at this point
so it looks like im going to be getting myself a 2001 prelude, and i was told that i should be looking at an RSX-S instead because the engines arent stable for boosting or something like that. im a big time newb to the world of tuning, and just getting into it recently since i only started getting enough cash recently...blah blah anyways. is it looking for trouble or was the guy mis-informed?
anybody here have a prelude with a turbo and running into troubles?
Old Jan 17, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Not to forum promote, but go here
http://www.honda-tech.com/zeroforum?id=16
Old Jan 17, 2006
andyman97's Avatar
Turbo Guru
I've heard from the horse's mouth that H22's are tricky to tune. But depending on the tuner, his experience and your management, the engine is capable of alot of power if you boost it.
Old Jan 17, 2006
acidbaby's Avatar
The Beez Kneez
you should go to honda-tech.com
there arent alot of prelude tuners out there so i wouldnt really trust anyone to just guess:/
you want to talk to somone that really has tried this and worked with the engine>
Old Jan 17, 2006
PunkingCivic's Avatar
I need TP for my bunghole
superstreet just had a white prelude (h22) that produced 510 hp boosted
Old Jan 17, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Wrong website??
Old Jan 17, 2006
Draven2's Avatar
small cities make me poop my pants
Draven2 is a jewel in the roughDraven2 is a jewel in the roughDraven2 is a jewel in the rough
I Might be able to help you out. I've got some buddies that do a lot of stuff with Preludes. Mostly older than 01 but the info should still be relivant.
Old Jan 17, 2006
Curiouz_G's Avatar
Curiouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really niceCuriouz_G is just really nice
alot of people on that forum go N/A and spray instead of boosting it...
Old Jan 18, 2006
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
h22s are like k20s higher compression etc...you have either tune it really well and/or build it
Old Jan 18, 2006
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
Depends on what H22 it is. A lot of the JDM H22a motors have Nikasil lined cylinder walls, not cast iron cylinders. The thin aluminum walls dont like much boost. Some of the USDM ones have iron sleeves but the cams arent anywhere near as good from what I understand. I think there are a few different compression ratios as well. My buddy and I built an H22a turbo. We had the block sleeved though. Lower end built as well. Stock cams and intake manifold. Car makes 451whp and 398 ft/lbs of torque peak. Thats using a cheap ebay header, the car is getting a new manifold and retuned to 500+ on 93 octane. BEAST!!! Get HONDATA!!!!! Like an s200 w/Boost Option run on a P28 ECU should do the trick. www.jdmfabtech.com The accord page.
Old Jan 18, 2006
ajhdragon's Avatar
7thgens official a$$hole
you hav eto tune it well if going with higher boost. but the H22 is a good engine because it is completly soild block. The F22 is not a good block for boosting because of the way the clyinders are held into place, you would have to get a float ring. but the H22 is a screamer of an engine.
Old Jan 18, 2006
i beg to differ, there are lot of people that boost the f22s in accord because they had such low compression and had cast iron sleeves
Old Jan 18, 2006
Thats what I've read about 6 mnths ago from Sport Compact Car
They said old accord 2.2 handles boost very well. Cant say more, just dont remember.
Old Jan 18, 2006
well ill tell you first hand, cause i had a boosted f22 92 accord before the civic...took 9lbs like a champ
Old Jan 18, 2006
ajhdragon's Avatar
9psi is still low boost imo
Old Jan 19, 2006
well there are guys that boost up to 15psi...i just played it safe...plus those motors were old as hell w/ high mileage (i boosted mine with 110k)
Old Jan 20, 2006
Boods's Avatar
lol, off topic at the end, but thanks guys.
Old Jan 21, 2006
Michalo187's Avatar
Abortion Survivor
I would supercharge it instead and just add on some more bolt ons you should be happy
civic1316
May 29, 2015 05:13 PM
autowill
May 15, 2015 11:36 AM
superstanko
Apr 28, 2015 04:38 AM
