I may have just had an epiphany....
Old Jan 16, 2006
Boilermaker1's Avatar
Jap-Euro Fusion
Got to thinking about this, it makes some sense, but I'm not sure if its a big enough port.
A catch can done right (and emissions passable) requires you to disconnect the PCV line, put a baffled catch can w/o an atmospheric vent in and connect it to the intake PRE-turbo. All well and good.
Now.... the smart part.... when you do this, most things say to just cap off the hole in the IM.... but wait a sec, wouldn't that make the perfect vaccum source for all the other crap? I'm just thinking forget T-ing a line, just plug a vac source line into that send it to a vac manifold and go. Why wouldn't this work? Cuz it sounds to me like it should work perfectly.
Old Jan 16, 2006
cg95660's Avatar
Wanna see a donkey show?
cg95660 is an unknown quantity at this point
Do yo u mean the im or the intake pre turbo? If its the im it would be under pressure from boost. Two things I remember about pulling vacume is placement will give you different readings.......such as pulling vac for a vac adv distributer if pulled down low on a carb will be diff if pulled from a higher source which could give you incorrect advance at the wrong time. So if pulled say before turbo when the turbo boosts it may be too much vacume.
Old Jan 16, 2006
Jap-Euro Fusion
Catch can routes PCV valve -----non-vented can----- pre turbo
It leaves a hole in the IM, which was the vac source for the PCV line which now has a new vac source (the turbo compressor). Instead of filling the hole in the IM, make use of it for feeding a vac. dist. block for the DV, Emanage sensor, etc....
Old Jan 16, 2006
cg95660's Avatar
You could always rig up a vac guage to that source and see if it is operating corectly.
Old Jan 16, 2006
i think it would work
Old Jan 17, 2006
skipbarber's Avatar
how big is that port on the IM?
Old Jan 17, 2006
Jap-Euro Fusion
However big the PCV hose is. I don't know because I didn't go digging for it last night.
Old Jan 17, 2006
djmota's Avatar
its pretty big if i remember right. around 1/2 inch.or a little less.
That port should work fine as a vacum/boost source.
Old Jan 18, 2006
skipbarber's Avatar
if its 1/2" that would be perfect.
Old Jan 18, 2006
Jap-Euro Fusion
I don't think its 1/2" thats friggin enormous.
I've heard 3/8" which sounds more realistic to me, and thats still a useable tap for a gauge, a MAP sensor and a BOV.
At 1/4" you're probably starting to run out of the ability to use it as a tap, but I really hope the PCV isn't that small.
Old Jan 21, 2006
Jap-Euro Fusion
I got my head under the hood today, the PCV port appears to be on the order of 1/4". I don't think its big enough to support a whole bunch of stuff, BUT, it should be big enough to support 1 item, like a direct tap for a boost gauge. thats probably going to be the most accurate place to tap that anyways, but it looks like the brake booster or something still needs to be tapped.
