k24 crankshafts
Old Jan 9, 2006
civicex9980's Avatar
civicex9980 is an unknown quantity at this point
k24 crankshafts
I need some help. I have searched all over and haven't found any info on the crankshafts that come in the k24's. I want to know if there is a difference between the crankshaft from a k24a1 and the one from the k24a2. I think that i heard they are but don't know for sure. If so, Is one gonna be better for boost than the other. Also, is there a stroker kit for the k24, if so who makes it. Thanks guys
Old Jan 10, 2006
tfnaaf's Avatar
BLDNPSI Mod
i would suggest asking HERE But you may get lucky in this thread
Old Jan 10, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Personaly I dont think crankshaft makes difference when boosting. Its a strong piece as it is, so it wont get bent or crack under boost.
The only differnce it will make if a2 has lighter crank then a1, but I doubt it.
Also, I dont know off hand, but if bore and stroke same on both engines(?), crank is most likely the same.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
Bonobo
Oct 2, 2015 06:58 PM
7thgensurvivor
33
Sep 5, 2015 08:20 PM
aultman1990
Jul 9, 2015 08:27 PM
