yes or no?
Old Jan 2, 2006
02Civking's Avatar
02Civking is an unknown quantity at this point
yes or no?
NOS Dry 50 shot? Yes or no?
Old Jan 2, 2006
Michalo187's Avatar
Abortion Survivor
.......................Why not?
Old Jan 2, 2006
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
No!
Wet!
Old Jan 2, 2006
drunkenmagnum's Avatar
wet is safer but dry should be ok.
Old Jan 2, 2006
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
"NOS Dry 50" - new drink of somekind?
I'd say "Go for it!"
Let us know how it tastes...
Old Jan 2, 2006
HyaBoosta's Avatar
I say No! Go with the wet alot safer for a stock motor. I ran mine with colder plugs and sprayed for a year till i boosted. never had a problem and a really easy install. Just make sure you don;t get copper plugs.
Old Jan 2, 2006
show0and2go's Avatar
show0and2go is an unknown quantity at this point
Wet indeed.
Old Jan 2, 2006
boricua_civic's Avatar
In love with Diana...te amo
boricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond reputeboricua_civic has a reputation beyond repute
Have to agree, go with wet; safer...
Old Jan 2, 2006
civic01vtec's Avatar
If it was a 35 shot, i would say dry.......but for a 50, go with the wet.
Old Jan 2, 2006
02Civking's Avatar
ok wet seems to be the majority, You guys think I can safely run a 50 shot on my stock engine with a few mods if its a wet system instead of dry....so I need iridium spark plugs and thoughts of probably a stage 1 clutch for my everydaydriver....I will not be spraying everyday.
Old Jan 2, 2006
not safely. you only get a certain amount of uses before the engine blows
Old Jan 2, 2006
mndthegap1's Avatar
get a wet kit.
it couldnt hurt to upgrade the clutch.
and yeah you could run a wet 50 shot on a stock d17 there are plenty of people on these boards running a 50 shot on a stock block.
i would get the plugs.
Old Jan 2, 2006
andyman97's Avatar
Turbo Guru
So, on average how many uses will you get with a wet 50 shot? How about a 75 shot?
Old Jan 2, 2006
turboengnr's Avatar
DONT PANIC
of course the wet is safer than the dry shot.
The wet shot actually adds more fuel!
the dry shot has NO RETURN LINE to put the regulator on. Therefore, you CANNOT INSTALL A DRY SYSTEM!
Old Jan 2, 2006
Havok2k1's Avatar
Wicked Pissah Admin
Wet ONLY.
