dezod el setup
Old Dec 30, 2005
mskatingd's Avatar
mskatingd is an unknown quantity at this point
dezod el setup
wonderin what u guys thought about a dezod el w/GT3582R setup. Too laggy?(ps: building motor)
Old Dec 30, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Its just me... but that turbo seems ENORMOUS
Old Dec 30, 2005
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
just a little. lol
Old Dec 30, 2005
eye_see_you's Avatar
let the devil out
giganormous is the term
Old Dec 31, 2005
andyman97's Avatar
Turbo Guru
You'd be good with a t3/t4e. Dezod's turbos are good. Depends on your goal as far as power.
Old Dec 31, 2005
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
HUGE! That would have nasty lag on a d17.
Old Dec 31, 2005
dezod's Avatar
7thgen Power Maker
GT35R would make power for about 1500 RPMS......TOO BIG!
Old Dec 31, 2005
Michalo187's Avatar
Abortion Survivor
yeah that is way way way to big. Like andyman says i would use the t3/t4e or ask yourself how much power you want to make and then choose a turbo like that.
Old Dec 31, 2005
mskatingd's Avatar
even with stage2 cams etc... and raised rev limit with ems
Old Dec 31, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I got a stage 3 turbo cam custom ground, redline at 7500 and i think any more than a 60 trim t3/t04e would be laggy on the street for sure. the turbo is spooled around 4k. Losing any more of the power curve due to lag would suck *** in between shifts on the street. IMO If you hit 250 whp you would see that for a streetable civic, you'd have more than enough to hand a ton of people their asses on a silver platter. If you are going to the track to do all of your racing and can spend a bunch on tuning an EMS to keep that thing spooled better then maybe I'd consider a huge *** turbo.
My strategy: LEARN TO WALK BEFORE YOU RUN. Its ok to plan for the future with upgradabilty in mind, but if you walk into it hoping for a 400whp D17 because you slapped the biggest crap that money could buy onto your engine, you will surely be dissapointed. Its about putting your time in and finding what really works in real life, not on paper. There is no easy way to make the most usable HP. Its not in a book or a parts catalog. Consider the advise that these guys give, even if its not what you wanna hear. Its a time/money saver to have such a great tool like this site. Make the most of it.
Old Dec 31, 2005
mskatingd's Avatar
thanks a lot for the info i get what u mean and def take everyones advice into consideration whether i agree or not, i think i will take it down a notch so that i can make some streetable power, but not entirely sure yet, well see how things go
Old Jan 1, 2006
turboengnr's Avatar
DONT PANIC
so what all do you (or will you) have done that made you think you need 650 hp worth of turbo? especially since you were asking about a T25 and an HKS cast manifold in your last thread.
Old Jan 1, 2006
02fpcivic's Avatar
turboengnr
My thoughts precisely. Too much of this going around considering all that has been done with your typical SOHC Honda. By now all of these questions should be answered by either common sence or by poking around the internet for a few minutes. How many SOHC turbo setups include a turbo big enough to blow you're average house down??? IDK anymore. LMAO
Old Jan 2, 2006
mskatingd's Avatar
alright after my last turbo flop i posted i did more research, but id like to find a more in depth thread on a/r's and what combinations do what going higher on the compressor less on the turbine vise versa, and one other thing can i run a larger turbo at lower psi till my engine is built so that i dont have to go through the trouble of changing turbos/ re routing piping etc or will it lag too much to be worth it and just save and do it all at the same time (haha what run on sentence) thanks
Old Jan 2, 2006
turboengnr's Avatar
DONT PANIC
do it all at the same time.
Old Jan 3, 2006
mskatingd's Avatar
decided on t3 super 60 then t3/t04e (50trim) down the road
Old Jan 3, 2006
andyman97's Avatar
Turbo Guru
Why would you get a less powerful turbo now? Seems like a waste of money.....
HondaGuy7
Feb 22, 2016 01:00 PM
