T3 Super 60 Prices?
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
T3 Super 60 Prices?
What have some of you gotten for brand new T3 Super 60 turbos? (not rebuilds) (Please do not post EBAY garbage, legit businesses only)
Just curious. I have seen Turbonetics charge upwards of $730, but that it is not unusual for their stuff.
Reason why I am asking, we recently became a WD for Innovative Turbo Systems and I think they offer some SLAMMIN deals on T3 turbos. I will post some prices VERY soon after some feedback. I am trying to get management to come to a great price for 7thgeners.
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
There are also some REAL good prices on T3/T4 turbos too!
Old Dec 16, 2005
nismostreets21's Avatar
nismostreets21 can only hope to improve
http://www.turbocalculator.com/sale-garrett.php 359 without wastegate n i think 60 more for internal
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
Originally Posted by varner88
how much on the t3/4 thats what im going to be looking for after xmas. also whats the difference in the greddy emanage and the untimate emanage?
PM me for pricing on the turbo at this moment.
Difference in the e-manages? Options.
Blue:
e-Manage is an inexpensive programmable fuel management system that allows you to properly tune your factory fuel system without having to change the entire factory ECU system to an expensive "stand-alone" unit. The e-Manage system is a universal "piggy-back" type unit which taps into most Japanese factory ECU wiring, by utilizing the existing sensors. Basic functions will allow the user to slightly alter factory injector duty-cycle (± 20% at 5 preset RPM points) by intercepting and altering airflow or MAP sensor signals. For Honda VTEC cars you can adjust the VTEC shift point. Additional features are built into the system but are only accessible through the use of the e0-1 programmer or our PC-Windows based "e-Manage Support Tool" communication software (Please see our Authorized GReddy Support Dealers for more information). There is a 16x16 airflow adjustment map, larger main injector correction adjustment, upgrade air flow meter adjustment, boost limiter cut, anti-engine stall, VTEC-fuel adjustment, real-time map trace, real-time display, real-time communication and basic Data-logging. With the use of our "Optional Injector Harness" and the software, the unit has the ability to control an additional 16x16 injector duty cycle map and the controls for adding up to 2 additional sub-injectors. If the "Optional Ignition Harness" and the software are used the unit has the ability to control a 16x16 ignition timing map. All of the above maps can also be map-traced in real-time as well. If the factory range of map or airflow meter is surpassed, you can incorporate our "Optional GReddy Pressure Sensor and Pressure Harness" to set larger scales of adjustment. All installation and tuning should only be made by a trained technician with proper air/fuel monitoring tools. (Some functions may not be compatible with some applications.)
Ultimate:
Ideal for optimizing and fine-tuning performance products such as; Exhaust, Air Intake, Intercoolers, Boost Controllers and Turbo upgrades, the e-manage Ultimate does it better than any other system on the market. The GReddy e-manage Ultimate does what no other piggyback ECU can, engineered to preserve the best features of the original e-manage (Economically priced, there is no need for tuning from scratch and it is compatible with most Japanese performance vehicles). Some of the new Ultimate features include; add and subtract fuel and ignition maps, a two-preset memory, A/F Target Map (for self tuning), built-in adapters and correction maps, and extensive data logging with Map Tracing for easier tuning. The new e-manage Ultimate includes the Support Tool CD to access all features from a standard USB cable.
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
Originally Posted by nismostreets21
i think on turbocalculator.com is like 349 bucks
Those are remanufactures or rebuilds. Sorry.
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
so which one out of the 2 is a better choice and how does it compare to aem ems i plan on running 15psi total once im done building my motor but im gonna start with 7-8 around there.
If your running 15 PSI, I would say AEM EMS. That system defeats both E-manages with the options and being a standalone system. The data logging and control of the AEM EMS is 2nd to none.
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
ok i jus saw on turbo calc 449 for a brand new garrett t3/t4 and i beleive 57trim and .50 ar compressor housing and 63 AR turbine housing and 6 month warranty
That turbo is too big for the D17. Talk about 1500 RPMS of usable power.
BTW, that is a good price, but I still am skeptical of it because they sell so much re-man stuff and I have seen huge companies sell a similar turbo for atleast $250 more. These companies are VERY well known and sell TONS of turbos.
Old Dec 16, 2005
dezod's Avatar
7thgen Power Maker
haha i wouldnt have no idea i just saw it i dont know much about turbo's just the basics.
All the more do your homework and ask the pro's.
Old Dec 16, 2005
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
550 new
Old Dec 16, 2005
skipbarber's Avatar
atp turbo $625 http://www.atpturbo.com/Merchant2/me...egory_Code=TBN
Old Dec 17, 2005
dezod's Avatar
7thgen Power Maker
Originally Posted by skipbarber
Not bad. I think we can beat that. Still whirling up numbers.
Old Dec 19, 2005
dezod's Avatar
7thgen Power Maker
Sometime today I will post some T3 Prices
Old Dec 19, 2005
dezod's Avatar
7thgen Power Maker
T3-.42 A/R compressor, in a .36, .48 or .63 Exhaust A/R $ 600 shipped
T3-Super 60 in a .48 A/R Exhaust jacket $600 shipped
T3/T4-.50 A/R compressor, in a .36, .48 or .63 Exhaust A/R $615 shipped
T3/T4-.70 A/R compressor in a .36 A/R, .48 or .63 Exhaust A/R $630 shipped
These are just a handfull of the prices.....we have prices for Ball Bearing, crazy custom apps and much more.
These all use Garrett Technology. SPA is the company.
With respect to Innovate Turbo, THEIR T3 Super 60, T3/T4 Street Heat turbos are also available.
Old Dec 19, 2005
dezod's Avatar
7thgen Power Maker
If enough people want a GB on these turbos...prices can come down some.
Old Dec 19, 2005
hey i want to get your pnp emanage harness after new year but this is 100% working right according to the diy and all? i'm not gonna have cel problems or anything?
Old Dec 19, 2005
dajackal's Avatar
The Jackal
dajackal will become famous soon enoughdajackal will become famous soon enough
how much for the t3?complete package?
Old Dec 19, 2005
dezod's Avatar
7thgen Power Maker
Our pnp harness is wires perfectly. We have sold countless amounts.....Just set your jumpers, and rotary settings and voila...done.
Old Dec 19, 2005
dezod's Avatar
7thgen Power Maker
What do you mean 'complete package'?
cukaracha
Aug 27, 2015 02:02 AM
knknif
Aug 4, 2015 06:11 PM
JDMnoob
Aug 2, 2015 02:38 PM
viperGTS
Jul 27, 2015 08:40 PM
