the turbo setup I am thinking off
Old Dec 14, 2005
02LX's Avatar
02LX is on a distinguished road
Please give me any suggestion, especially where I say I do not know!?
dezod equal length T3 manifold
T3 super 60 from turbo calculators
don't know what size intercooler
RSX 450cc injectors
fuel pump
emanage
ec01 boost controller
8.5:1 compression pistons
crower stage 2 turbo cam
all new internals
HKS SSQ
Tial wastegate with 8psi spring
boost timer
what am I missing? please give feedback!
Oh yea, I drive a 02+civic+coupe+lx, that I am going to do a headswap on.
Old Dec 14, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Forget the headswap. Its easier to tune a turbo car without variable timing.
There's a lot of parts seemingly missing for that much work, I also think with a completely built motor I'd be using more than e-manage to keep an eye on it (EMS).
Old Dec 14, 2005
02LX's Avatar
so you say, do not get the headswap, no cam change, just new internals? and you are saying that I should change the from the emanage to the EMS?
Old Dec 14, 2005
Jap-Euro Fusion
ohhhh thats right, Crower only makes the cams for the A2 head. I guess you have to swap it. Generally its easier to tune a turbo when you only have to make a set of maps for 1 cam profile instead of 2.
And yes, with that much work, I'd be using an EMS.
Old Dec 14, 2005
02LX's Avatar
so go ahead with the head swap, and get the AEM ems? is the EMS a replacement for the stock ecu or piggy back?
Old Dec 14, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
RSX 450cc injectors
fuel pump
emanage
all new internals
HKS SSQ
boost timer
what are you goals with turbo set up?
Old Dec 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
EXZACTLY!!!!
My goal building a turbo system was i wanted to hear PSSSSHHH! lol
Old Dec 14, 2005
02LX's Avatar
250+ whp
and good 1/4 mile times
Old Dec 14, 2005
02LX's Avatar
Originally Posted by tfnaaf
EXZACTLY!!!!
I do love that sound too
Old Dec 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
its been done with no internals
Old Dec 14, 2005
02LX's Avatar
dunno never thought about that route since I have the vtec head in the garage
Old Dec 14, 2005
skipbarber's Avatar
the greddy e01 boost controller is nice, but kinda excessive. Get a more basic controller and use the left over money for an AEM wideband a/f gauge.
Old Dec 14, 2005
02LX's Avatar
what is the name of the more basic version
Old Dec 15, 2005
C2i0v0i1C's Avatar
SuperMODrizd
thats a big project for as lil hp that u want to get out of it.
ur missing a **** ton of small pieces too.
if ur rebuilding....bearings, all new gaskets...head studs/bolts
if ur doing a head swap ur going to have some wiring harness issues to asses. ur going to have ECU probs
Old Dec 15, 2005
03EXD17's Avatar
03EXD17 is an unknown quantity at this point
A more basic boost controller is a single or dual stage manual boost controller by TurboXS. With the dual stage boost controller it comes with the option of switching from low to high boost within your vehicle. Price around $120-220.
Old Dec 15, 2005
02LX's Avatar
So what do you suggest, I do with this set up them, I want to get everything finalized before I head into it?
Old Dec 15, 2005
02LX's Avatar
Cool thanks, I will think about getting it.
Old Dec 15, 2005
tuningmycivic's Avatar
tuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to alltuningmycivic is a name known to all
i thought that was why he was going for the EMS?? so he wouldn't have to worry about trying to pin-out the ecu wiring harness on a non-vtec vehicle...
agree about the bearings, gaskets, and such...might as well do it right if you're gonna rebuild.
any thoughts on PnP?
Old Dec 15, 2005
02LX's Avatar
I am not rebuilding the block, because it is pretty much new, it is just reinforncing the head, I was going to get new gaskets anyway
Old Dec 15, 2005
250+ whp
If only for this, then,
you will just need dezod kit and aem ems.
Clutch and 2.5-3" exhaust.
Old Dec 15, 2005
02LX's Avatar
are you serious that is it, it would not be cheaper if I was to peice it together myself?
Because I can get a garrett T3 super 60 for alittle over 500 from turbo calculators? Bcause dezod's kit is going to run about 3500, and the EMS is another 1500 roughly.
Old Dec 15, 2005
^^If you can weld and fabricate, then it is definately cheaper.
Piece by piece is ok as well, but you are running into a lot of downtime, little bits and parts that will be missing and extra hassle. Leave it upto pros.
But all in all, turbo kits i find to be better, its like slap it on and go.
Old Dec 15, 2005
02LX's Avatar
The thing is that I want the Dezod equal length manifold and he does not have it in his kit as of yet. I like kits as well because each one has some part or parts in it that I would like to substitute. I am wondering if I could talk to dezod to see if I could get the kit with the equal length mani
Old Dec 15, 2005
C2i0v0i1C's Avatar
SuperMODrizd
FYI=8.5to ! compression pistons means ur rebuilding the block. therefore u need new bearings and gaskets. if u dont i have no sympathy for u 10 miles down the road.
if ur going to do the head work and build the block, might as well sleeve it. get the AEM EMS and do it all right.
a turbo/engine build is never squared away from the get go. something will always need to be bought in order to get a final product.
Old Dec 15, 2005
^^I'm with you on this one, if you're doing major work on the engine, then you need bullettproof it all around.
But how I think is, since he already has lx, then there is no real need for him to switch to ex head. At least I dont see why.
So with what he has + kit and good tune on aem, he is good to go.
Old Dec 15, 2005
02LX's Avatar
but then I would not be able to change my cam? and I agree with you, I might as well do it right. should I just mount it all up and do it at once, or do it as I go
Old Dec 15, 2005
C2i0v0i1C's Avatar
SuperMODrizd
RSX 450cc injectors
fuel pump
emanage
all new internals
HKS SSQ
boost timer
intercooler piping!!
piston rings
head studs/bolts
engine bearings
gasket kit
depending on mileage...timing belt
BOV flange
silicon couplers
hose clamps
anodized fuel fittings
FPR
clutch
high WHP=axles
notice the bold
Old Dec 15, 2005
02LX's Avatar
notice the bold
thanks a bunch, at least you guys saved me from making some major mess ups
Old Dec 16, 2005
And there is more: Oil sending, oil retun lines and water cooling lines for turbo, external waste gate, boost gauge.
And it may not be all.
Old Dec 16, 2005
02LX's Avatar
I am going to take it one step at a time and keep you guys posted on here as to how I am doing, and asking for gradual feedback along the way.
