Looking for a fitting... don't know where to look
Old Dec 4, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
I don't know what its called, which obviously doesn't help my looking.
There exists a fitting, it seems to be popular for tapping oil pans for things like return lines, you drill a hole, and the fitting has an outside part and an inside part. The outside part looks like a sensor bung (sometimes its male, sometimes its female) and the inside part looks like a nut (it basically is). Both parts have a deformable gasket/washer on them so you put the outside one in the hole and tighten it down with the inside one, and the gaskets sandwich around the pan and seal the hole.
Does anyone know what the hell this thing is? And where I can find one?
Old Dec 4, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
something like that?
Old Dec 4, 2005
Jap-Euro Fusion
Thats kinda close.... the ones I've seen don't have allen screws.... its just like a hollow bolt with a nut. But that's along the lines.
Old Dec 4, 2005
booba5185's Avatar
k, i'll keep lookin
Old Dec 4, 2005
booba5185's Avatar
kinda like something like this but straight on with rubber gaskets right?
Old Dec 4, 2005
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
might try summitracing.com and check for some earl's fittings
Old Dec 4, 2005
Jap-Euro Fusion
I found it....
Its called a bulkhead fitting. They're for fuel cells.
Old Dec 4, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
From other sites, I've seen people referring to summit racing, as the place to get oil pan fittings.
Old Dec 4, 2005
puidokas's Avatar
puidokas is an unknown quantity at this point
is this a good alternative to welding
Old Dec 4, 2005
Thats kind I have. Works beautiful. No leaks, easy to install.
Dave88LX
Jun 2, 2016 03:43 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
lilrob1213
37
Jun 29, 2015 06:45 PM
intensity
May 12, 2015 10:43 PM
pheaton
May 4, 2015 08:26 PM
