so apparently rsx-s tranny bolts up to f20...
Old Nov 8, 2005
skipbarber's Avatar
i was over on H-T and saw this:
pretty interesting. It was only a matter of time before someone gave it a shot. I just think it's funny that no one, including myself, thought it was possible. Since the s2k is rwd. (well, apparently these guys thought it was possible)
so who is gonna be the first to step up to this one?
Old Nov 8, 2005
Bad_Civc's Avatar
If Your Reading This Your Dee Dee Dee
Bad_Civc is an unknown quantity at this point
hmm screw a k20 ill do an f20 ... but the wiring would be a BITCH .... and custom made mounts , prolly could use t he rsx-s subframe like you would in a k20a2 swap ..
Old Nov 8, 2005
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
that's cool...that'd be a unique swap
Old Nov 8, 2005
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
can you plz link us to the original thread..
Old Nov 8, 2005
HondaLuver's Avatar
Its a celebration bitches!
screw a f20, i love my k24.. more tq and power down low
Old Nov 8, 2005
2k1civic01's Avatar
2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice2k1civic01 is just really nice
yes sir!!...My friend has a k24 hybrid swap in his EK and it's ****ing awesome!!!
Old Nov 8, 2005
PunkingCivic's Avatar
I need TP for my bunghole
damn
Old Nov 8, 2005
dezod's Avatar
7thgen Power Maker
True I love a nice mid-ranged and top end car.
K24= 160 lb/ft @ 4000 RPMS & 166 hp @ 5800 RPMS
F20= 162 lb/ft @ 6800 RPMS & 237 hp @ 7800 RPMS
F20=TOP END!
K24 doesn't even know what that is. F20 has a 8000 RPM redline. Nuff said.
F20 flexed hard on my 2JZGE from 70-125mph. SIIIIICK top end.
Old Nov 8, 2005
dre2600's Avatar
I wonder if the gearing would be appropriate for the F20 and if the tranny can hold up to all the higher revving.
Also, I thought the F20 had a 9000rpm redline and the F22 (the 2.2L in the latest iteration) had something like 8600? or something to that effect?
Old Nov 8, 2005
Michalo187's Avatar
Abortion Survivor
thats cool. and that f20 produces good power
Old Nov 8, 2005
scansel912's Avatar
scansel912 is just really nicescansel912 is just really nicescansel912 is just really nicescansel912 is just really nice
This is off topic, but if you ever look at an RSX from the side, just imagine how sick it would be if it were a RWD car.
Old Nov 9, 2005
spoonEM's Avatar
omgwtfbbq mod.
hmmm....i must see the original story behind this.....
Old Nov 9, 2005
HondaLuver's Avatar
F20=TOP END!
who cares about top end, i got more top end than a f20 at 7.3k
i was comparing my car... and basically, you can compare my car to a tuned tsx motor
f20 revs to 8900 and a f22 is 8k
Old Nov 9, 2005
skipbarber's Avatar
there is no original story, the thread started off as a question whether or not the f20c head would bolt up to the k20 block. Then someone suggested swapping the whole motor and those pics were posted, the first one is going into a lotus i believe.
Old Nov 9, 2005
dezod's Avatar
7thgen Power Maker
If your racing, everyone does. That top end is what keeps your car rollin and accelerating from the TQ from the lower RPMS.
The figures I quoted were directly from Honda on 2006 Spec 2SK & an Accord
I doubt you have more HP than an F20 at 7.3K
I am not trying to sound like an ***, but your claiming your K24 swap to be the unbeatable against a motor that is proven better than almost EVERY Honda & Acura N/A in a race without heavy motor work.
Old Nov 9, 2005
ragingSPAM's Avatar
I just burnt my tongue
he has a hybrid swap which is using a K20A2 head with K24 block...i've seen it get massive power but yes the F20C is a pretty freakin crazy too...
Old Nov 9, 2005
acjones21's Avatar
4 cyclinders down, 4 to go.....
acjones21 is an unknown quantity at this point
torque and proper gearing > all top end
any street driven car will feel better with some torque, I'm with hondaluver, besides, there aren't many modded K20s that still have 160whp, boltons, cams and hondata will put you neck and neck with an F20 easily
Old Nov 9, 2005
dezod's Avatar
7thgen Power Maker
True however the K24 does not have good gearing IMO.
I doubt that the K24 will keep up with an F20. The F20 is a little over 200 at the wheels with no work what so ever.
Let's not forget the fact of power to weight ratio too.
Old Nov 9, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I have heard from several people that the F20 head and K20 heads are interchangable. Judging from pics of side by side HG comparison it looks to be true. The K20a and a2 heads are supposed to be better than the F20. K20 head design contributes to most of the engines efficiency. I wouldnt be surprized if there are a few reports of guys with stand-alones doin k20 I-vtec setups on their S2ks. Think about it, K20a head K20 ITBs, if the S2k header flange is different, the port spacing is almost identical so a flange swap wouldnt be much work or a custom header and lots of dyno time could be done, nice set of TODA cams or something, Rewired harness for K-pro or AEM, improved I-vtec could possibly turn an S2k into (more of) an all motor monster. Maybe Im reading too much into this, hehe.
Old Nov 9, 2005
Sick Cycle's Avatar
Sick Cycle is an unknown quantity at this point
hondaluver has a k20a2 tranny.
power to weight? ... k24 civic > s2000.
on another note ... in my opinion, an f20c would be a nearly useless swap if you're planning a fwd car. a built k-series motor would make ridiculous power... check out the latest honda tuning (is that the right one?) mag ... there is a built k20 making just over 300 whp n/a, revving to 10000 rpms.
seeing as how f20c ecu's can't be modded, I would think that it would be very difficult to be able to tune it properly
Old Nov 9, 2005
02fpcivic's Avatar
IDK how much an F20 costs in comparison but I think a K20a would be much better in a 7th gen civic to be honest. S2k motors are pretty sick though.
Old Nov 9, 2005
jhonsok's Avatar
The blackbeauty ES1.
Yeah..K series in our cars is the more logical. haha..
But, it'd be cool to see an RSX competing in D1 one day..haha..
Old Nov 9, 2005
dezod's Avatar
7thgen Power Maker
Why are we talking about it into the EM2? The F20 would never go into a EM2 chassis without severe modification and $$$$$$$$.
With respect to a race:
The AEM EMS solves tuning for the S2K (AEM part# 30-1052). No problem then.
The S2000 only weighs 2855, a K20 swapped EM2 weighs about the same.
Originally Posted by dezod ON 1/26/05
Vehicle weight, driver weight, brake set-up, wheel size, wheel weight, cooling capacity with different engine bay confinements all play a role as well.....
True-a swap SHOULD reveal more power than the original motor in the car because why would you swap in the first place....ya know?
i.e.-K20 in a EM2 > D17 in an EM2
The curb weight, just taking that alone into account,
The Type S is 2840 lbs
The EX Civic is 2597 lbs
Old Nov 9, 2005
Sick Cycle's Avatar
what??
curb weight for an 01-03 EX is 2550. 04+'s are about 50 pounds heavier. But then again, not everyone swaps into an EX civic either, so weight is pretty variable. How does adding a K series motor add 300 pounds on top of the D17? it adds 150 pounds at MOST.
I never said anything about the f20c in an em2 either ... perhaps other people, but not me. I'm talking about K em2 vs. s2k
hmm, I didn't know the ems was out for the s2k.
Old Nov 9, 2005
dezod's Avatar
7thgen Power Maker
what??
Those weight specs are directly from Honda. Ok, even add 150lbs to 2500lbs = 2650lbs. Even low ball it because of DX/LX weighing like 150 lbs less. The S2K still only weighs 2840 with a 8K+ redline and about 20-30 more hp. It will be a nice mid range race, but I think the S2K will crush it on top end.
Old Nov 9, 2005
Hurts2bStock's Avatar
Shinier than yours, meatbag
I had heard of a company putting f20's or f22 in Elise's.....anyone know if thats what were looking at here?
Old Nov 9, 2005
Sick Cycle's Avatar
a built K24 will make more power than a built F20C.
the F20C would only be faster because of the rwd advantage and the ability to run much wider tires.
however, given a fwd built f20c (like the one that was originally posted here) and a built K24 frankenstein, the K24 would always come out on top.
C'mon .. even you know that there is no replacement for displacement
I could be wrong, but I haven't heard of any drag cars running built F20C motors in the 9's n/a
Old Nov 9, 2005
Spoolin's Avatar
spoolin by you
Spoolin should not be trustedSpoolin should not be trusted
they are interchangeable, but the k20 and f20 engines spin in different directions.......
you would prob have to reverse the cams if you want it to work...
Old Nov 9, 2005
dezod's Avatar
7thgen Power Maker
FWD F20 defeats the pupose of the conversation and arguement. Now your REALLY stretching it. LOL
Yes, but boost levels the playing field. I have been saying it for years.
Old Nov 9, 2005
Sick Cycle's Avatar
haha yeah ... but isn't the topic of this thread the use of a k20a2 tranny with an f20c? .. I think it's a really stupid idea haha.
someone should build an awd k24 frankenstein turbo using element awd components. that would be something really noteworthy.
