retarding timing in a 7th gen
Old Oct 21, 2005
boostdynamics's Avatar
boostdynamics is an unknown quantity at this point
does any one know how to retard the timing on the 7th gen civic which has distributer less ignition when you turbo charge a car
iam going to run abt 7 psi daily on a sohc non vtec 1500cc d15y3 ................. how do you think this motor is gona hold? i
Old Oct 21, 2005
mrDFWmechanic's Avatar
this is just a wild guess but adjusting the cam gear
Old Oct 21, 2005
lol yea you need an aftermarket cam gear. i think the only decent one is by aem. make sure you get the 5 bolt model. the 3 bolt will slip over time. then its a matter of loosening bolts and turning the wheel to whatever +/- you want.
Old Oct 21, 2005
i understand that the distributer is controled by the inlet cam..rite? so i need to adjust the inlet cam n retard it or advance it? no dynos in my country people so id be workin on rules of thumb!!! Ill be runing 7 psi n to be on the safe side u need to retart almost a degre of timing with each pound of boost ..so do i retard the camtiming 6-7 degrees???
Old Oct 21, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
holy crap guys, this is a case of the blind leading the blind. This has been discussed a million times over. Cam timing is not the same as ignition timing. Leave the cam alone. With 5 pounds the factory ignition timing will prolly be ok with no.7 plugs. Any higher than that and you should take at least a half degree out for every pound of boost, depending on how good or bad your tuning is. If I were you Id invest in an e-manage with all the harnesses for boost,ignition, and fuel control, bare minimum, toss in a set of rsx injectors too. If there are no dynos in your area you desperately need a wideband datalogger. The cost of boosting doesnt appear that bad at first, but you will find out how expensive it can be. Taking shortcuts is how you find out the hard way. You wind up screwing up your car, dishing out more dough to fix it, and then buying the stuff you should have bought in the first place anyways. Many of the other boosted members will agree with me on this.
Old Oct 21, 2005
S2000man01's Avatar
O RLY
thank God someone beat me to it. 02fpcivic is the ONLY ONE you should listen to so far in this thread.
Old Oct 21, 2005
turboengnr's Avatar
DONT PANIC
depending on the quality of the fuel you have, you can safely run between 7-9 psi with the correct plugs.
If you run some plugs like Iridium IK26's or autolite racing AR-3932's, then you can actually get away with a little more on 93+ octane.
And remember, buy the best quality gas you can. Do not get gas from arco or some mom and pop store. I stick with Chevron and Unocal.
Also, to retard the timing, you need some sort of engine management like an emanage, AEM, split second, etc.
Old Oct 21, 2005
civic01vtec's Avatar
emange or ems is the only way
You cannot adjust ignition timing with a cam gear
btw......this has be discussed many times....all you have to do is use the search function at the top of this page.
Welcome to the site
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Lt. Dan
May 13, 2015 12:42 PM
pheaton
May 4, 2015 08:26 PM
Myredjonda
Apr 14, 2015 07:00 PM
