Question about Wastegates
Old Oct 14, 2005
Michalo187's Avatar
Abortion Survivor
Ok i have a question about wastegates. Right now i have the stock sf internal wastegate but i wanna change to a external wastegate. Is this possible? Where would i make the flange for the wastegate to go? Also if i do upgrade which wastegate do you recommend i get i wanna go really high boost settings planning on running 20 once i finish my block
Old Oct 14, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
If you want to convert to external wastegate. You have get a new manifold and downpipe flange to block the internal wastegate.
edit : I said go w/ tail wg
Old Oct 14, 2005
Michalo187's Avatar
Abortion Survivor
well is there better internal wastegates
Old Oct 14, 2005
iamboo's Avatar
Retired - SoCal FI Mod
what is your goal of having a better wastegate? do you want to run more boost than the internal wastegate allows?
Old Oct 14, 2005
dezod's Avatar
7thgen Power Maker
The turbo will have to be modified for the new gate. Also, The manifold would then to have to converted to accept an external gate. Chances are that you will also have to also change that turbo too. It might not be that efficient at those higher boost levels. I have mapped out a potential few for that PSI.
I recommed TiAL. The best bang for your buck. Feel free to drop me line. We are a TiAL distributor.
Old Oct 14, 2005
Michalo187's Avatar
Abortion Survivor
Thats a lot of modification but i really want to have an external wastegate What is the sf wastegate supposed to go up to in boost?
Old Oct 14, 2005
tfnaaf's Avatar
BLDNPSI Mod
Not to put you down or anything, but why do you want an external wastegate? Is it cause somebody told you its a much better system? Well for high boost max HP applications they are prolly right. But dont forget you have a d17. And the internal wastegate can run as much PSI as your boost controler( if you have one ) will allow you to. For most boost applications the internal will be more the enough.
Old Oct 14, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I have to agree. Just save the money for internal or something. I mean look $500+ for new manifold, tail wg $250+, turbo (maybe) $700+. you are looking at 1k+ just to convert to external.
Old Oct 15, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
I have seen some applications that change the exhaust housing on the turbo so it allows you to run an ext wg. I think the internal gate its self is welded shut, not exaclty lure. But like the others have said play it the cost efficient way.
Old Oct 15, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
^^^it is a flange that does that.
http://store.yahoo.com/cheapturbo/gart3forstyl.html
even though u did that. You still will have to get new manifold and wg.
Old Oct 15, 2005
skipbarber's Avatar
you dont need a new manifold, you cut a hole, weld a flange, install gate. So really youd just need the wastegate and some welding, and get a flange the blocks off the turbo's internal wastegate port.
Old Oct 16, 2005
iamboo's Avatar
you might as well get a new manifold... especially if you have the older SF manifolds that aren't equal length... it's better in the long run and it'll look cleaner than just drilling a hole and trying to weld a plate inside the manifold...
Old Oct 16, 2005
skipbarber's Avatar
i dont remember what the non-EL SF manifolds look like, Im using an SF EL manifold and just welded a flange near the collector. but i guess if your manifold wont accomodate a flange, youd have to get a new one and probably a new down pipe too.
robjcivic
Mar 12, 2017 12:10 PM
JMKendrick
Sep 16, 2015 06:17 PM
Bricoleur
Sep 9, 2015 12:23 PM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
junkyardguy
Sep 2, 2015 06:07 PM
