Who wants to be the first with a custom D17 Quaife LSD?
Old Sep 24, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
Josh aka Drivetofast has his old D17a1 open differential sitting around, so he decided to compare it with the DC5-R LSD that he pulled out of my motor. Apparently he found out that the LSD bearings hold the same exact part number and the bolts holes line up. Theoretically, with a little custom work, he could probably get a Quaife, Kaaz, Cusco, DC5-R or any other K20/K-series differential to fit.
Here's the bad news:
- notice how I put "custom" in the title. The holes on the differential gear need to be enlarged to accommodate the K20 differential bolts. You will need to drill them out slightly bigger.
- the axles are bigger for the K20 ... a new/custom half shaft will have to be used. We're guessing a B-series or an Accord half shaft will work. More clarification will follow once he gets off work today and checks this post.
other than those things, according to him, the measurements for the differential (ie. height, width, etc) appear to be exactly the same
so who's gonna be the first?
Old Sep 24, 2005
andyman97's Avatar
Turbo Guru
OMG I want one sooooo bad!!!!!!!
I'd actually called quaife a while back wanting them to make one but they weren't very optimistic about it
Old Sep 24, 2005
ajhdragon's Avatar
7thgens official a$$hole
damn would be nice seeing as im looking at getting a new cluth/flywheel soon. might think about it while i have the trany out.
Old Sep 24, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
I'm game... as long as it works. Who wants to install it for me?
Old Sep 25, 2005
FuzzBeC00L's Avatar
Fuzzy Boy
Goodluck whoever wants to try this
Old Sep 25, 2005
Michalo187's Avatar
Abortion Survivor
dam this would be great
Old Sep 25, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yes ... drivetofast and I need someone's d17 to experiment on ... since neither of us have one anymore ...
anyone wanna try it? ;P
Old Sep 25, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
phantom lsd?
Old Sep 25, 2005
Blahman240's Avatar
check above posts. Also, what would be needed if this some how got ****ed up to fix it back to stock?
Old Sep 25, 2005
04|5spdCivic's Avatar
Wish I had a Turbo 3)
04|5spdCivic can only hope to improve
that would be so awesome if you could get it just right. let us no who decides to do it and if it turns out alright
Old Sep 25, 2005
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
really would like to see this work
Old Sep 25, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
yeah ... I saw the post ... but really, we would like to find someone local (or if someone can do the work themselves)...
I know it sounds silly, but we're not exactly overflowing with money, so you will have to provide the LSD and tranny... this is also experimental. Hopefully someone has an extra D17 tranny lying around in case this doesn't work (but we're pretty sure it will)
oh yeah .. and the phantom grip "lsd" is a piece of crap ... in my opinion. not to put anyone's opinion down or anything.
Old Sep 25, 2005
im stock now! T.T
i have an ex tranny laying around but second gear pops out of gear.
Old Sep 25, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
I will have a tranny if you guys want to use it as experiment??? You guys can sell it w/ the lsd, if everything work out. You have to pay for the shipping though. A little help for the d17s.
Have to wait until the shop pull it out first though.
Old Sep 25, 2005
Blahman240's Avatar
well, tell me what I have to do, and I'll buy the lsd and tranny. I don't have much experience with lsd's or trannys for that matter.
Old Sep 25, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
civic_redline: if you want to donate the tranny for the cause, that would be good. 2nd gear popping out is not a problem, Josh is only looking for one to test fit. we would do the labor and everything for it ... we don't know exactly which axles to use as of yet, but we are gonna mess around with some k20 and b-series axles to see if we can frankenstein some axles. for testing purposes, we will use a DC5-R lsd ... if you want the finished product to be put into your car, we will put it in, parts and everything for you ... but the cost will be $1100 for parts, labor and everything... otherwise we will put the tranny back to stock, at no charge. This is just FYI if you're interested.
blahman: I can't go in-depth on how to do it yet other than what was already covered, since there are a few fine edges we need to iron out. We don't know for sure if it will work, which is why we're still on the experimenting stage to see what will fit and what will not. Josh is almost positive the LSD will fit ... but the only problem we have now is finding the correct-sized axles.
The D17 does not use a half shaft ... K series does, so we need to frankenstein some axles. We are gonna attempt to experiment with some B-series axles and K-series (anyone have any they can donate?) ... we do have a pair of D17 axles already though.
Old Sep 25, 2005
turboengnr's Avatar
DONT PANIC
i can probably get you guys a set of whatever axels you would need. You would just have to come up here to get them.
Old Sep 26, 2005
Drivetofast's Avatar
Supercharged k20a3
Drivetofast is an unknown quantity at this point
I will post some pix soon so you guys can see how close they are
Old Sep 26, 2005
Supercharged k20a3
this one is the DC5-R LSD with the D17 gear
the D17 is on the left and DC5-R LSD on the right
and like i said the bolts are biger on the K20 diff so the gear will have to be drilled out to fit
Old Sep 26, 2005
iamboo's Avatar
Retired - SoCal FI Mod
this would be really good for you turbo guys out there.... all that extra torque off the line could be transfered to both tires instead of just one....
traction = faster times on the 1/4 mile and a must for you auto crossers and road racers
Old Sep 29, 2005
ritalin's Avatar
ritalin has a little shameless behaviour in the past
Don't laugh but look into an obx diff. Its a quaife knockoff, costs half the price new and comes with a lifetime warranty. A couple local hondas use them. 300whp, 400whp, 500whp and no problems.
Old Sep 29, 2005
Supercharged k20a3
the problem with OBX and all the other LSD's is that they don't make an aplication for a D17 thats why im tying to get this to work
Old Sep 29, 2005
ritalin's Avatar
In due time. How much different are the 7th gen civic tranny's from the 6th? Still hydro I assume.
Old Sep 30, 2005
Supercharged k20a3
Alot
Old Sep 30, 2005
k20txem2's Avatar
k20txem2 is an unknown quantity at this point
I well it could be an experiment, think i still have my old 5spd tranny somewhere.
Old Oct 4, 2005
vicride345's Avatar
vicride345 is an unknown quantity at this point
A noob question for ya? What will this do if it works properly? I would be interested but I wouldn't want to be the lab rat I just bought a new motor so I have to wait a little bit before I can possibley break something else.
Old Oct 4, 2005
turboengnr's Avatar
DONT PANIC
it would make both tires transfer power to the ground, not just one.
The problem with a spyder gear type diff. is that they will transfer power to the tire that has the least amount of traction. When one tire breaks loose, all the power is then transfered to that tire. This kills your accelleration and powered turning.
Old Oct 5, 2005
lovinthevtec's Avatar
lovinthevtec is an unknown quantity at this point
oil wont be an issue?
dc5 looks to be closed unless you took the cover off the d17?
Old Oct 5, 2005
tfnaaf's Avatar
BLDNPSI Mod
I've never had a d17 gear in my hand so bare with me Would it be possible to have a machine shop make a sleeve that would fit inside the bigger hole where the bolts go thru the lsd? Its the gear thats threaded yes? I would think that drilling and tapping the gear would weaken in. Wouldnt it be easier and safer with a sleeve in the lsd?
Old Oct 9, 2005
opto_isolator's Avatar
Why modify ANYTHING???
http://www.7thgencivic.com/forums/sh...2&postcount=16
Use a D16 differential! DUH!
