Injectors
Old Sep 22, 2005
jl8383's Avatar
jl8383 is an unknown quantity at this point
Injectors
Would anyone know any other injectors other than type s' that would work on our cars. I have some saturated RC310's and was wondering if those might work?
Old Sep 22, 2005
dezod's Avatar
7thgen Power Maker
Same CC as an RSX injector. Why even bother?
RC does not have nay injectors that clear our rail and TPS issues. I have spoken with them many times about this.
Old Sep 22, 2005
jl8383's Avatar
because i have rc's and was just wondering if I might be able to use them.
Old Sep 22, 2005
dezod's Avatar
7thgen Power Maker
To be honest, doubt it. Most of the RC injectors are too long or stout to fit.
Old Sep 22, 2005
jl8383's Avatar
Yeah i didn't think they would work I just had them layin around from my be series and dont feel like going to acura. Thanks
Old Sep 22, 2005
jl8383's Avatar
Do you have to do anything special to the type s injectors or do they just plug in like regular ones?
Old Sep 22, 2005
Rufus's Avatar
I have Bluetop 450's
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
you just need a spacer and longer fuel rail bolts.
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
Not true.
Old Sep 23, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
I remember someone said that srt-4 injecters fit and he had the pics to prove it.
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
They did not because of the TPS sensor.
Those were 440's if I remember correctly. Hyaboosta tried them and it was a no go.
The 310 MAY be a different story, however the 440's didn't work. The RC I think also require you to solder in the connections unlike the RSX ones.
Old Sep 23, 2005
Michalo187's Avatar
Abortion Survivor
well how can you help us out dezod? You got connections get some that clear
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
Workin on it.
Old Sep 23, 2005
jackburton's Avatar
Yeah was not sure, couldnt remember details.
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
what else do you need to fit rsx injectors?
I am using SRT injectors. They fit fine. All i needed was a spacer and longer bolts.
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
Directly from an SRT-4? Or RC replacements for the SRT-4?
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
directly from the SRT4 Stage 3 upgrade
they are supposed to be 680 cc @ 58 psi
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
From Dodge's Performance Division?
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
yea. They are the black injectors with the blue top and bottom
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
****, im sorry. They are stage II injectors.
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
Pics of the injectors themselves?
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
give me 5 mins. They are sitting downstairs, ill go take a pic
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
Very curious to see the length of them.
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
uploading some pics right now.
I installed them on my car really quickly also to show that they clear.
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
Old Sep 23, 2005
dezod's Avatar
7thgen Power Maker
In this case, they are probably the same length, if not shorter as the RSX injectors, but are not as wide as persay the 440 RC's..... + rep for coming through on pics.
BTW, clip connections special on them? I am assuming they have to be soldered in to work, not PnP like the RSX injectors.
Old Sep 23, 2005
Michalo187's Avatar
Abortion Survivor
will only the srt 4 stage two fit? Will other srt fit?
Old Sep 23, 2005
turboengnr's Avatar
DONT PANIC
I have fit the stock stg 0 injectors, stage 1 and now stage 2 injectors.
They do not plug directly in. You have to solder in the injector clips off the SRT harness. And the little steel clips that hold the injector into the rail does not fit either. So the bolts are the only thing holding it in the rail (like all old style hondas)
Old Sep 24, 2005
C2i0v0i1C's Avatar
SuperMODrizd
all i have to say is that my b series 440s had serious mods that needed to be done including wiring that had to be done in order to make them work
Old Sep 26, 2005
dezod's Avatar
7thgen Power Maker
I am sure.
