440's with emanage-issues
Old Sep 9, 2005
andyman97's Avatar
Turbo Guru
Ok, I'm running 440's on the emanage. I've talked to dezod about this and I'm not able to come up with a solution to my issue.
For those of you running this setup, you're probably familiar with the p1106 code for baro/map sensor voltage being out of range. We know this is caused by the injector correction factor on the emanage altering the voltage from the map. Now, if you're running rsx injectors, you can still use the emanage to pull enough fuel to keep a smooth idle. But, the actual adjustment factor only allows you to pull up to 50% out. This isn't enough for 440's.
So, I've been having to deal with the 1106 code because I can't completely disable the correction factor and keep the car running. I'm on the verge of getting the aem but I hate to give up after all this work. Any thoughts, comments, suggestions?
Old Sep 9, 2005
dezod's Avatar
7thgen Power Maker
Try tightening up the correction factor: example 275/300
This will pull a very little bit of variation. Only problem I forsee at that point would be to go ahead and take away some fuel in the idle and low end because the 440s will be flooding the motor with fuel. If you want to drive here, I will play with it. I can't guarantee results.
Old Sep 9, 2005
andyman97's Avatar
Turbo Guru
Lol, I would if I hadn't blown my motor for other reasons. I spent the past two days in Houston. Jason from autologic is my tuner and he tried every combination and variation he could and we either got misfires from too rich or p1106 cels. We couldn't get rid of them both.
Old Sep 9, 2005
dezod's Avatar
7thgen Power Maker
It is a super delicate balance with this ECU. I know because I spent tons of time tuning to get rid of it. It is possible, but takes a ton of time and playing around to get it.
Old Sep 9, 2005
andyman97's Avatar
Turbo Guru
Well that was a big thing with it. We played around with it for 2 days and I'm sure if we had rsx injectors we would have been able to figure it out.
Let this be a warning to those who want to run bigger injectors than rsx with the emanage.....DON'T!! Lol.
Old Sep 9, 2005
tfnaaf's Avatar
BLDNPSI Mod
Good point. Im still running the RSX's and im pulling about 20% on my WoT and im @ 7psi. So i imagine i have a lot of room to grow for boost being im pulling out fuel still?
Old Sep 9, 2005
andyman97's Avatar
Turbo Guru
Depends alot on your fuel pressure. You can get alot of fuel out of those injectors but when you start adding alot of fuel pressures, your injectors stop pulsing normally and become erratic and inconsistant. I wouldn't use more than 60 psi fuel pressure on any injector. Start going over that and you take a risk. That's why so many people lifted headgaskets with sf's fuel kit. Way too high and unsafe fuel pressures.
Old Sep 9, 2005
tfnaaf's Avatar
BLDNPSI Mod
I'm running straight 45 psi with no boost reference connection!
Old Sep 10, 2005
andyman97's Avatar
Turbo Guru
Then yes, I'd say you can probably run those injectors up to 15 psi or more maybe.
Old Sep 10, 2005
Rufus's Avatar
Ok wait...I just got Blue Top 450's and I have Emanage too as I peice this turbo together. You saying I should get rid of these 450's before I even put it on?
Old Sep 10, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
I had so much trouble with the emanage and 440s. I had to cut back on the FP and sometimes it would be ok, sometimes it wouldnt. Either way it ran rich when not under boost. Thank god for AEM engine management hehe.
Old Sep 10, 2005
andyman97's Avatar
Turbo Guru
Exactly. You are going to have problems with that large of an injector with the emanage. Either go with rsx injectors or aem ems.
Old Sep 10, 2005
Rufus's Avatar
That sucks. Ok so if I have a brand new emange minus the cable kit how much more am I gonna have to fork out for the AEM?
Old Sep 10, 2005
andyman97's Avatar
Turbo Guru
You can find it for right at 1300 or less. WELL worth the money.
UrbanImport
21
Jul 8, 2006 09:45 PM
UrbanImport
Nov 18, 2005 11:28 AM
UrbanImport
51
Jun 8, 2005 02:40 PM
UrbanImport
29
Oct 25, 2004 01:18 PM
UrbanImport
Aug 17, 2004 10:14 PM
