Hasport MM vibrations
Old Aug 31, 2005
C Orndorff's Avatar
Once boosted now i-VTEC
C Orndorff is an unknown quantity at this point
Arrow Hasport MM vibrations
Anyone with a k20 motor swap and hasport motor mounts have vibrations in idle and below 1.5-2k rpm. My hasport MM are very stiff and are great for acceleration and what not but suck when you are in stop and go traffic. What do you guys think about them?
(P.s. I know they have to be stiff enough so the motor doesn’t bang around because are engine bay is smaller bla bla bla)
Old Sep 2, 2005
cwick187's Avatar
cwick187 is an unknown quantity at this point
I have friends that have swapped out MM in EX's and Si's (Hasport and some other companies) and all of them VIBRATE the CRAP out of the cars....I wouldn't want my daily driver vibrating like that...Aggravating isn't it??
Old Sep 2, 2005
01EXtc's Avatar
01EXtc is an unknown quantity at this point
Thats because you have a solid motor mount. If you were to have a mount with an insert such as rubber, the rubber would absorb most of the vibration.
Old Sep 2, 2005
cwick187's Avatar
Yeah, my one friend that has the 2002 Si had poly inserts and they caused more vibration than with his Hasport mounts...Don't know why, but they did...I guess the rubber ones would be a little different, but I don't think the rubber would be as good as the poly/solid...IMO anyways
Old Sep 2, 2005
HondaLuver's Avatar
Its a celebration bitches!
yes...
Old Sep 2, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
modifying cars is all about tradeoffs.
most of the time, the pros outweigh the cons.
Old Sep 2, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
They will shake the car a bit.
Part of the deal.
Old Sep 2, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
of course they are going to cause vibration's. They're not stock.
mgrantaz
General
May 2, 2022 05:40 PM
jdawgzcivic
17
Feb 1, 2020 04:16 PM
Wariogamer
Sep 29, 2015 09:49 AM
vImpostor
Vancouver
Sep 8, 2015 08:08 PM
FistRock
Sep 4, 2015 08:00 PM
