MSD digital rpm window switch problem
Old Aug 19, 2005
sitinduk's Avatar
sitinduk is an unknown quantity at this point
I'm trying to install a MSD digital rpm window switch (P/N: 8969) to control my nitrous kit. There are 4 wires that need to be connected.
RED -> +12V
BLK -> Ground
YEL -> (Normally Open) Ground of nitrous relay for solenoids
WHT -> Tach signal
I was connecting the WHT wire to engine speed pulse wire (BLU wire, pin 26 on
Connector E (31 pins) of the ECU), but when I do this, my dash tach dies and the window switch shows 0 rpm.
Next, I tried the connecting the WHT wire to the crankshaft position wire (BLU wire, pin 7 on Connector A (31 Pins)). My dash tach is fine, but the window switch shows the wrong rpm. I think the rpm it shows is half of what it really is.
Redline04 used the same window switch w/ WHT connected to engine speed pulse (26-BLU-Connector E) w/ no problems. His car didn't have a factory tach, but mine (LX) does.
Old Aug 19, 2005
sitinduk's Avatar
How about the MSD dis tach driver PN 8913? would this solve the problem?
Old Aug 23, 2005
djmota's Avatar
There is a blue wire in front of the battery with a rubber cap on it. use this wire and you should be fine.
Old Aug 23, 2005
sitinduk's Avatar
I tried that wire. When I connect it there, my dash tach doesn't work and the window switch shows 0 rpm.
Old Aug 24, 2005
MiamiUgen7's Avatar
are you disconnecting these wires or taping into them? you should use a wire tap and not splice the wires...
Old Aug 24, 2005
sitinduk's Avatar
I was tapping the wires.
Guy on MSD forums said I would need the dis tach adapter (8913), since one of the negative coil wires didn't work either.
Old Aug 29, 2005
sitinduk's Avatar
Ok, the Dis tach driver (8913) did the job . The window switch had to be programmed for 1 cylinder mode.
If any1 else has a problem with an rpm switch or aftermarket tach, definitely try the dis tach driver.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
Wild Cranker
May 19, 2015 06:10 PM
dooner24
Apr 14, 2015 07:51 PM
Cypher
Dec 15, 2001 07:25 PM
mwwhonda
Nov 7, 2001 07:24 PM
