Opinions?
Old Aug 2, 2005
dezod's Avatar
7thgen Power Maker
Opinions?
We are looking to offering 375cc injectors as part of all of the kits now. These are not RSX, Honda or Acura injectors. These are Accel, which are made by Denso (OEM) injectors. They are quite cost effective and I think will be an excellent added value to the Stage I turbo kit.
Old Aug 2, 2005
tfnaaf's Avatar
BLDNPSI Mod
Sounds like a nice option. It seems some are complaining that the rsx injectors arent enough for the higher psi systems. But maybe even an option for even larger injectors wouldnt be a bad idea either
Old Aug 2, 2005
dezod's Avatar
7thgen Power Maker
The RSX are 310cc, these are 375cc. So indeed, this will solve that issue.
Old Aug 2, 2005
HyaBoosta's Avatar
I'de rather pay more for RC injectors. I know denso;s are oem and all but when boosting higher levels I would rather leave that to someone who has been proven over and over. How's the status on the larger fuel rails coming?
Old Aug 2, 2005
turboengnr's Avatar
DONT PANIC
i would use denso.
if it is good enough for GM to run in the LS2 and LS7, then theyre good enough for me to run.
Old Aug 2, 2005
Jrfish007's Avatar
Originally Posted by turboengnr
i would use denso.
the LS2 and LS7 are N/A engines. N/A engines and boosted engines run better having different flow patterns. If you really want to do it right, you should get an injector with a specific flow pattern for boosted cars. This will help in long term, and RC has the best name IMO for this type of stuff. If I remeber right the RC webpage even explains all this. Not that I'm in the market for a turbo kit, but if I was pay extra for RC too.
Old Aug 2, 2005
dezod's Avatar
7thgen Power Maker
You guys are referring to injector selection with respect BSFC (brake specific fuel consumption). On an N/A motor it is .50 lbs, FI will use ~.60 lbs.
As long as this equation is taken into account with injector selection & proper impedence, brand is just a name.
Old Aug 2, 2005
turboengnr's Avatar
DONT PANIC
ok, how about this.
the accel injectors are extremely comparable to the bosch injectors, right?
The new Ford GT uses bosch injectors on its Twin screw supercharged motor
Old Aug 2, 2005
turboengnr's Avatar
DONT PANIC
well said dezod
Old Aug 2, 2005
dezod's Avatar
7thgen Power Maker
well said dezod
Thanks!
Old Aug 2, 2005
HyaBoosta's Avatar
but whats the satus on the fuel rail?
Old Aug 2, 2005
Jrfish007's Avatar
I see... Okay, makes sense
Old Aug 2, 2005
Michalo187's Avatar
Abortion Survivor
Well how is the install going to be? Are they going to be direct replacement? I think thats a good start if they are direct replacement
Old Aug 2, 2005
dezod's Avatar
7thgen Power Maker
Still workin on it.
Old Aug 2, 2005
andyman97's Avatar
Turbo Guru
My opinion....regardless of brand, I wouldn't spend money on something smaller than a 400cc. It'll be a limiting factor, big time. Even for people who say "I will be happy with 200 hp or low boost," they never are. That's why I didn't even mess with rsx injectors.
Old Aug 2, 2005
dezod's Avatar
7thgen Power Maker
We can accomodate up to and over 500cc.
Old Aug 4, 2005
dezod's Avatar
7thgen Power Maker
A pic of one of the Accel 375cc injectors
ID:	58083   Click image for larger version
Old Aug 4, 2005
HyaBoosta's Avatar
but wouldn't 500's hit the tps with the stock rail?
Old Aug 4, 2005
dezod's Avatar
7thgen Power Maker
that was concern of mine, but apparently 500cc SRT-4 injectors from RC fit our car. Someone posted them:
http://www.7thgencivic.com/forums/sh...d.php?t=221261
Old Aug 4, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
557CC to be exact, which is where about the e-Manage can control upto....
Old Aug 4, 2005
HyaBoosta's Avatar
those weren't SRT4 injectors they were RC 550's for RSX. They didn;t fit and hit the TPS and he's selling them on ebay now because of that. I talk to him alot
Old Aug 4, 2005
dezod's Avatar
7thgen Power Maker
So that thread was kinda BS then?
Old Aug 4, 2005
Michalo187's Avatar
Abortion Survivor
so when will these be made and are they going to be direct replacement?
Old Aug 4, 2005
dezod's Avatar
7thgen Power Maker
Injectors in general are direct replacement. These will be available VERY soon (1-2 weeks)
Old Aug 4, 2005
andyman97's Avatar
Turbo Guru
For those interested, you can run pretty much as big an injector as you want if you take the time to install a d16 intake manifold. I'm thinking of picking up a venom manifold for it....not sure yet, very expensive part.
Old Aug 4, 2005
tfnaaf's Avatar
BLDNPSI Mod
what about a Throttle body spacer, to raise the TPS up higher? Any thoughts?
Old Aug 5, 2005
HyaBoosta's Avatar
I was thinking the same thing. He is selling them now after 3 days and I just won the auction on them so I will find a way to make them work and then go for 10psi.
Old Aug 5, 2005
dezod's Avatar
7thgen Power Maker
Good luck!
Old Aug 5, 2005
jackburton's Avatar
jackburton will become famous soon enoughjackburton will become famous soon enough
so rc 400cc injectors will be fine running 6-7 psi
Old Aug 5, 2005
dezod's Avatar
7thgen Power Maker
Sure.
