Fuel System related question for Turbo Application
PC Tech / Autocrosser
From reading and searching I understand that our fuel system is, of course, returnless and we are able to convert this to a return style. Then the other issue I see is with the fuel pump: 1) the FPR is on the pump itself and 2) we would have to install a external pump to increase fuel pressure/flow for higher flowing injectors.
Knowing this, I was reading some info on www.homemadeturbo.com and www.d-series.org relating to turbocharging the d15/d16 motor and for the fuel system, there was a picture where the fuel pump was taken out of the tank and a fuel line/pipe was put in line betwen the pickup screen and the pipe inside the tank then an external pump mounted outside the tank. Is this a valid option for our car's or will that cause a c.e.l. to come on or create some sort of problems?
Also I think a F.P.R. can be installed in line between the fuel rail and the fuel line is that correct?
thanks
thanks
thanks
thanks
Originally Posted by tfnaaf
Just mount it in the tank and elimanate the in tank regulator... click my signature for pictures
vtecbrah
May 31, 2015 01:24 PM
werdnahall
May 17, 2015 11:37 AM
Ninetyatecivic
May 9, 2015 07:48 PM
cloudguy
Apr 28, 2015 05:02 AM
