Fuel system enhanced (back to fabricating)
Old Jul 20, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
Well, like always I'm up to experimenting and fabricating new items.
Here you'll see the first instalment of what will be the fuel supply that will work in conjunction with the return system of Street Level
This reservoir will hold about a liter of fuel always availble and will be mounted where the battery was in my car.
T- Rex Inline pump will push the fuel to the new fuel rail shown below that fits the RSX injectors then to the pressure regulator, back to the reservoir that also will have a return to the main tank.
Here are the pictures of the items,enjoy
Will show it when done, and will take to the dyno and see how it works.
Old Jul 20, 2005
turboengnr's Avatar
DONT PANIC
why are you adding a reservoir on the return side?
Old Jul 20, 2005
supermex's Avatar
Not on the return.
But for the return system.
This reservoir is installed right after the feed line coming from the tank then
to a line pump
to the rail
to return back towards the reservoir
and if reservoir overfills
back to the main tank.
The idea is to always have enough fuel volume while boosting for long period of times.
Old Jul 20, 2005
tfnaaf's Avatar
BLDNPSI Mod
guess im confused on how and why? BTW, the fuel rail looks BAD @$$
Old Jul 20, 2005
supermex's Avatar
HOW?
Is a bit confusing to explain as well, but just read post #3
Then look at the holes, on the reservoir then go to sleep on it.
Why?
Need more acurate,volume and flow of gas for future upgades.
and because I can
the car is running fine and will be tuned soon.
The tuner from Titan Motorsports thinks is a great idea for semi stock fuel systems and can't whait to thinker with it.
Old Jul 20, 2005
turboengnr's Avatar
DONT PANIC
ok. I misunderstood. I thought you were installing it inline on the return line.
Old Jul 21, 2005
supermex's Avatar
No prob is an idea enginered by a local racing fabricator guy here in town.
It also took me some time to digest.
We kept runing out of gas presure while boosting 14psi with 340cc injectors on the dyno although we are using a walbro pump and a big the fuel line.
So will see how this will work.
Old Jul 21, 2005
MiamiUgen7's Avatar
any plans on making more fuel rails similar to that one and selling them?
Old Jul 21, 2005
dezod's Avatar
7thgen Power Maker
We will be. This is derived off our idea....
http://www.7thgencivic.com/forums/sh...ht=fuel+system
Old Jul 21, 2005
supermex's Avatar
I'll live that up to Dezod.
My stuff is purely experimental and I wouldn't be able to support the product.
Don't want any type of Stafford fabrications situations.
Localy I can hook up friends, but most ppl I know here aren't carzy like me to do engine mods.
If you are whiling to come to Kissimmee Central Fl
I can guide you in the right direction
Old Jul 21, 2005
C2i0v0i1C's Avatar
SuperMODrizd
you have got to be the coolest person alive, all this new **** makes me jealous! damnit!
Old Jul 21, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
Looks good. I like that fuel rail. What have you done with the in-tank assembly? Will there be a gravity/siphoning effect to get fuel to the reservoir or do you have another pump in-tank?
Old Jul 21, 2005
Havok2k1's Avatar
Wicked Pissah Admin
Interesting. I'd like to see how well it helps the fuel starvation issue.
EdiT: You still have feed issues with a walbro 255?? Hmmm
Old Jul 21, 2005
supermex's Avatar
Yes, I do have the walbro pump and bigger lines and they are good.
Is the actual pump assembly that's restrictive on the outlet.
When boosting longer than 10 sec I see a slight drop on pressure.
The line goes dry.
I think because the p&p head bigger pistons and bigger TB the car is getting more air therfore needs more fuel while boosting.
I have the RSX 340cc injectors and I want to use 440 cc. and boost 14/16 lbs
So I'll need more fuel this may help.
The car is running now with the new fuel system in place but is still on the body shop getting a face lift.
I'll post the results after tuning and pictures of the system installed soon.
Old Jul 23, 2005
supermex's Avatar
[QUOTE=1siksivik][QUOTE=Supermex]but most ppl I know here aren't carzy like me to do engine mods.
you just wait my friend. after my trunk and wheels are done ENGINE TIME.
i will be lookin for your expertise and helpin me through my project.
oh and i forgot to add your custom stuff looks sweeeeeeeeeeet.
Let me know when you ready.
I may suggest do the engine mods before fiber glass trunk.
The trunk will be to heavy to see the full potential of your engine.
CarStuff
Dec 6, 2020 12:52 PM
ImmortalEX
Detailing
78
Sep 4, 2015 05:35 PM
Shakzhussain
May 17, 2015 12:03 PM
tylerginevan
Apr 27, 2015 12:29 PM
supercivic01
South
Nov 30, 2001 11:27 AM
