E-Manage w/ the Dezod D17 Kit is NOW PLUG & PLAY...S-AFC2 & V-AFC2 available as well
Old Jul 11, 2005
dezod's Avatar
7thgen Power Maker
We are woking it becoming full plug & play for the kit as an FYI.
The plug & play will include the main harness, injector harness & ignition harness.
UPDATE:
In the 7thgen section of our site: http://dezod.com/cat_7thgencivic.cfm
Under ECU Harnesses: http://dezod.com/cat_ecu_harnesses.cfm
Pure SEX!
4 in stock & ready to ship!!!!!
You will find plug & play E-Manage, S-AFC2 & V-AFC2 harnesses available for your 7thgen. Now wiring complex electronics just got easier....Dezod Style .
V-AFC2 & S-AFC2 harnesses are made to order, so please allow us some lead time. (This is due to the fact of decreased popularity with these units)
E-Manage plug & play harnesses with the Main, Injector & Ignition harnesses will be almost always in stock. We have 5 ready to roll as we speak. No cores required, no thought or effort involved. Just simple PLUG N PLAY. Enjoy!
Old Jul 11, 2005
rumptis's Avatar
rumptis is an unknown quantity at this point
That sounds awesome....The wiring is the only part that scares me with any car.
Keep us updated.
I hope to get your turbo kit once my Warranty runs out!!
Old Jul 11, 2005
TheSmuggler's Avatar
Hmmm plug in play? I mean can you elaborate on that for me?
Old Jul 11, 2005
4drcivic2k1's Avatar
Turbos, Engines, Chassis and Suspension Tech
4drcivic2k1 is an unknown quantity at this point
Boomslang fabrication manufactures a plug and play harness for the emanage in the 2001+ civics. Dezod is probably using this if my intuition is correct.
Old Jul 11, 2005
linky?
Old Jul 11, 2005
It dosent show an emanage harness for the 7thgen on there, but it says obd2 a or b.... hmmm
Old Jul 11, 2005
dezod's Avatar
7thgen Power Maker
Correct. Thanks to you insight a few weeks ago. It will eliminate a lot of tech calls and emails.
Old Jul 11, 2005
Hwoody77's Avatar
Hwoody77 can only hope to improve
How much is it?
Old Jul 12, 2005
MiamiUgen7's Avatar
how is a plug and play harness possible if some wires are required to be spliced and such?
Old Jul 12, 2005
dezod's Avatar
7thgen Power Maker
Very simple.
Old Jul 12, 2005
dezod's Avatar
7thgen Power Maker
Originally Posted by Hwoody77
How much is it?
Through us and with our turbo kit, $90 and it will include all of the harnesses.
Seperately, $175
Old Jul 18, 2005
dezod's Avatar
7thgen Power Maker
bump!!!
Old Jul 18, 2005
MiamiUgen7's Avatar
Originally Posted by dezod
Very simple.
care to explain?
Old Jul 18, 2005
tfnaaf's Avatar
BLDNPSI Mod
care to explain?
Save yourself from a headache, use one of our e-Manage PnP harnesses!
We supply the e-Manage sub-harnesses. No cores!
Fully plug and play.
Be sure to select the option you need.
Old Jul 18, 2005
dezod's Avatar
7thgen Power Maker
Originally Posted by tfnaaf
^^ Exactly.
Old Jul 18, 2005
Pedro Lopes's Avatar
Pedro Lopes is an unknown quantity at this point
ignition and injector harness correct
Old Jul 18, 2005
MiamiUgen7's Avatar
so does it replace the oem ECU harness with one already wired for the e-manage?
Old Jul 18, 2005
tfnaaf's Avatar
BLDNPSI Mod
My understanding is it goes in between the factory wiring harness and the ECU, and from this it then has its own harness thats goes to the e-manage. LOOKS like a very nice set-up. A little costly but for those who dont wnat to cut/splice thier factory harness its a very nice option IMO. And BIG time saver too
Old Jul 18, 2005
dezod's Avatar
7thgen Power Maker
Exactly.
Old Jul 20, 2005
dezod's Avatar
7thgen Power Maker
All set now. Any E-Manage ordered with our kit, will have the option of including all the harnesses and being plug & play.
http://dezod.com/pd_dezod_motorsports.cfm
Harnesses will be in stock & available for individual sale on the E-manage.
S-AFC2 & V-AFC2 will be order to order unless demand picks up.
http://dezod.com/cat_electronics2.cfm
Old Jul 20, 2005
taz757's Avatar
Those harnesses are pure sex. I'd definately consider picking them up because I'm basically lazy.
Good luck with the sales on those things dezod!
Old Jul 20, 2005
dezod's Avatar
7thgen Power Maker
Makes install 10 minutes flat.
Old Jul 20, 2005
sasquatch's Avatar
sasquatch is an unknown quantity at this point
holy crap batman!
That is just going above and beyond Dezod....wow.
Old Jul 20, 2005
dezod's Avatar
7thgen Power Maker
We are trying to bring the D17 over and above into the realm of the K & B series. We are continuing to strive and innovate on demands required by the D17. Pioneering always.....
Check out our EL mani too:
Old Jul 24, 2005
dezod's Avatar
7thgen Power Maker
updated 1st post.
Old Jul 24, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Any chance I can trade-in my TSI ecu for e-manage with harness, plug and play and rsx injectors?
Old Jul 24, 2005
dezod's Avatar
7thgen Power Maker
What am I supposed to do with it?
Learn what not to use with my turbo system.
Old Jul 25, 2005
exturbo6's Avatar
ok so i have e-manage with all 3 harnesses and the senor. if i want the plug and play i do not need the one that includes all 3 harnesses, i just neeed the plug iun play harness? sorry if it a stupid question, just a lil confessed.
Old Jul 25, 2005
tfnaaf's Avatar
BLDNPSI Mod
You should still need the map sensor and its harness, all other is taken care of with the purchased plug-n-play harness
Old Jul 25, 2005
dezod's Avatar
7thgen Power Maker
The harnesses we sell are the main, injector & ignition harnesses. If you need the pressure sensor & harness, that you will still need to purchase seperately.
