Smoke help, need some input.
Old Jul 9, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
K My car is tuned, sf turbo, rsx injectors, the whole works, been boosing at 5 to 6 psi for about 2 months now, everything was fine till this moring. STarted the car and somthing told me to look back towards the rear of the car, and guess what i found, white smoke comming from the exhaust. Im like mother *&*89 cause i already know its probley the head gasket or a crack in the head. How many people on here have had good luck with the honda nippon gasket? I went to honda today and talked to the techs since i use to work with them , and there seeing more and more of 2k1 civic with blown headgaskets around 50,000 miles. WHo else is having problems with there head gaskets? and does anyone have and links besides making a copper head gasket for aftermarket gaskets?
Let meknow
Jeff
Old Jul 9, 2005
robo1040's Avatar
Once you go Black on Black, You Never Go Back.
robo1040 will become famous soon enough
had the same problem, boosted my car with about 40k on it and blew the headgasket in several spots in a weeks time. i used the nippon leakless with ARP headstuds, and ive been good for a year now on 8psi.
white smoke is def coolent, id look into it.
Old Jul 9, 2005
Jeff's Avatar
Did you have alot of water in the exhaust when the head gasket blew?
Old Jul 9, 2005
Jeff's Avatar
Also can you send me a link to the arp studs?
Old Jul 9, 2005
robo1040's Avatar
eh dont know about the water, the was alot of **** coming out the exhaust! lol
you have to buy the head studs labeled for the D16az or somthing, they work for our D17. ill look for a link
Old Jul 9, 2005
robo1040's Avatar
http://www.nolimitmotorsport.com/prod/arp-208-4301
Old Jul 9, 2005
robo1040's Avatar
i found this in a post...
arp headstuds for $101 bucks shipped. i got them from here. they work for our engines as well.
wiredspeedlab.com----- order from here
ARP-208-4301 Honda D-16 10mm $89.00(make sure you get Z not Y) and tell them its for ur 7thgen. they hooked me up right. talk to alex.
Old Jul 9, 2005
Jeff's Avatar
Sweet deal ill give them a call on monday. When your gasket finally gave up did you happen to look at the tops of your pistions to see if coolant was washing the tops of them?
Old Jul 9, 2005
Michalo187's Avatar
Abortion Survivor
Hey jeff I just blew my headgasket last night same problem as you and i was only boosting 5 pounds entering the freeway going up hill o well i was going to be doing a head swap after vacation anyway so it doesn't matter to me i ordered the nippon leakless and now i want to get those headstuds if they really work.
Old Jul 9, 2005
supermex's Avatar
supermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to allsupermex is a name known to all
E-manage
Just get it!
Old Jul 9, 2005
Michalo187's Avatar
Abortion Survivor
we both have it
Old Jul 9, 2005
supermex's Avatar
Did you retard the timing under boost?
And if so how much?
Old Jul 9, 2005
Michalo187's Avatar
Abortion Survivor
Left that up to my tuner and yes he did retard timing
Old Jul 9, 2005
supermex's Avatar
Dam, that sucks.
The nippon gasket should hold is 3 sheets metal.
Old Jul 9, 2005
Michalo187's Avatar
Abortion Survivor
I ordered the head studs right now and I ordered the Nippon leakless gasket also. I seriously don't care because i was swapping the head pretty soon i just hope it doesn't happen again. My mechanic said we can o-ring the headgasket and it will never happen again what do you guys think about that?
Old Jul 9, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
I think you should have it re-tuned by someone else.
Old Jul 9, 2005
Michalo187's Avatar
Abortion Survivor
I think there is something wrong with my head because when i was N/A i had lots of trouble and blew the head gasket at 10000 miles now the car has 20000
Old Jul 9, 2005
supermex's Avatar
you can O ring the cylinders but if you do that you can't use a 3 sheet head gasket cause it won't set even and if it leaks again it will be in between the sheets.
A one sheet cooper gaskes will be ideal when o ring but no one makes it.
Old Jul 9, 2005
andyman97's Avatar
Turbo Guru
I agree, from all the problems you've had, it sounds like your tuner doesn't know what he's doing......I'd try someone else.
I don't know when people will understand that when you put 150 psi of fuel pressure to an injector, it will cause an inconsistent spray pattern and it will cause lean conditions....it's not that difficult of a concept, at least I don't think. But as long as people are using shortcuts for their fuel management and running in unsafe fuel conditions, problems are going to happen.
Old Jul 9, 2005
Jeff's Avatar
I had mine tuned by 2 different people. the second person is a hondadata tuner, and he knew the emanagelike the back of his own hand. Timming was ret, injectors were all set up correctly ran good. Just the headgasket is the weak link.
Old Jul 9, 2005
Havok2k1's Avatar
Wicked Pissah Admin
What would you prefer to blow, a headgasket or a piston? Cause if you detonate, one will go. Headgaskets are ALOT easier to change than a block or piston. O-Ring it and you choose the piston or block.... Think of a HG as a safety fuse for the motor.
I would strongly urge against the o-ring. And I agree with others, this guy has given you nothing but problems and an underpowered car. Find someone new.
Can a member from AZ help this guy out with someone that knows what they're doing??
Old Jul 9, 2005
civic01vtec's Avatar
I honestly don't know wtf you people are doing. I have almost 60,000 miles on my car. I have been boosted for 15 months and i run 9-10 psi daily. I am still using the SF fuel system, stock injectors with no tuning and i am still on my stock HG......i have zero problems. I admit that i may have run lean and have done some damage to my engine, but who on this site that is boosted hasn't ????
jtcavey
Sep 30, 2015 02:18 PM
Hollywoodsnake
Sep 20, 2015 12:58 PM
JMKendrick
Sep 16, 2015 06:17 PM
tomas6791
Sep 11, 2015 06:47 PM
Mannimarco
Sep 7, 2015 10:01 PM
