Emanage Ignition wiring; Coil Vs. Channel
Old Jul 2, 2005
andyman97's Avatar
Turbo Guru
Ok, so Jeff (Jeff) has been pm'ing me about the wiring schmatics of the emanage ignition wiring. His main question has been: Why not wire channel 1 to cylinder 1, 2 to 2, 3 to 3 and 4 to 4? He said that Hyaboosta has it wired this way and has no misfires. When I wired in my emanage initially, I read (I believe it was Opto's) DIY that said to wire cylinder 1 to channel 1, cyl 3 to chan 2, cyl 4 to chan 3 and cyl 2 to chan 4.
Well, if Hyaboosta is running cyl 1 to chan 1, 2 to 2, 3 to 3 and 4 to 4, it must mean that the emanage has no control over anything than altering the signal. Hence, hook up the emanage, any channel to any cylinder. Don't adjust the ignition settings and the car will run stock. When you boost, just make sure you remember which channel is wired to which coil and adjust accordingly.
If anyone has more insight to this or why this may not work, post it up.
Old Jul 4, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
Give input people!
Old Jul 4, 2005
Michalo187's Avatar
Abortion Survivor
I am using the Jeff way and it works great
Old Jul 5, 2005
tfnaaf's Avatar
BLDNPSI Mod
Guess you lost me, but after work today thats not hard. Im using the wiring that madwheels had posted as i recall and mine runs perfect idle/boost other then im pig rich above 3000rpm and need some tunning
Old Jul 10, 2005
andyman97's Avatar
Turbo Guru
Well, since there's been no real insight shed, I am going to assume that I am correct (I can't think of any reason this would be inaccurate) and I went ahead and updated my diy to reflect this new info.
Old Jul 12, 2005
HyaBoosta's Avatar
the emanage is universal so I would guess that no matter what channel you run it to it will retard the timing in that cylinder just as much as the other across the board. Unless your tunning each individual cylinder.
jordan1794
Jun 11, 2015 09:14 PM
Wild Cranker
May 19, 2015 06:10 PM
pincookie1
May 4, 2015 12:22 PM
Gunner
Engine DIY
Oct 6, 2012 12:37 PM
Dvlsh6
Jan 22, 2002 10:42 PM
