My car is finally tuned!
Old Jul 2, 2005
Michalo187's Avatar
Abortion Survivor
Well My car is tuned but with shitty *** numbers Wtf 160whp and 158 tq at 8 psi With no boost the car had 92 whp hahahahaha So i guess 160whp is way better than that. The temperature was 102 and humidity 25% i don't know if that has anything to do with it. It drives very good and does haul some pretty good *** i didnt get to test it out against any of my friends last night because 15 minutes from 1 hour drive my car just stopped and wouldnt start again don't know wtf happened but that got me even more sad shitty numbers and shitty end o well what can i do.
Old Jul 2, 2005
TheSmuggler's Avatar
It's because it was 102 out, your going to need to get it tuneda gain when the temp drops lol. You'll see better numbers as the temperature drops some more
Old Jul 2, 2005
Michalo187's Avatar
Abortion Survivor
^^^ The tuner said it should go up a lot once the temp goes down i hope it does i could't believe only 160whp untuned it was at 136 whp and then every tune it went up it seriously does feel very powerful for only having that. At 92whp with zero boost i am not stock i have flywheel and pulleys so imagine without that i would have about 85whp that is sad
Old Jul 2, 2005
Yeah, it'll go up quite a bit, and you'll be happy.
Old Jul 2, 2005
200whp's Avatar
200whp is an unknown quantity at this point
I bet its just the weather but hey its tuned now you just gotta get it running again
Old Jul 2, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
it has to be the temp outside. Have u ever drive the car in 100F (day) + and 70F (night). Big difference in between.
Any check engine light or anything?
Old Jul 2, 2005
Michalo187's Avatar
Abortion Survivor
The check engine comes up when i put the key in and it flashes 5 times i think then turns off the car turns over all the electronics work just wont start it was so sweet boosting for about an hour dam it picked up pretty fast and i just floored it and when i looked at the speedometer i was going 120 i was like holy **** better slow down. i have not driven it at night because it broke down around 5. How much hp do you think i will pick up once it cools down?
Old Jul 2, 2005
they say about 1 per degree
Old Jul 2, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
damn that sucks, 9x whp with pullies, ex runs 110 with a stick. Well temps get hot here but not 100 yet and at night its still freezing cold, but I do feel a dramatic improvement during night time driving. Enough to feel more than the gains of i/h/e.
Old Jul 2, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
how much did u pay for tunning. (PM me if u don't want to pos)
go scan the cel and see what it comes up.
Old Jul 2, 2005
Michalo187's Avatar
Abortion Survivor
tunning was 250
Old Jul 2, 2005
exturbo6's Avatar
well im sure when the weather cools down your car will be nice. please by me charges 150 for 3 tunes.
Old Jul 3, 2005
andyman97's Avatar
Turbo Guru
What kit are you using? Turbo specs?
Old Jul 3, 2005
those are good numbers...if you have an auto. I'm assuming you do because your starting hp is very low. Autos usually end up around 150whp with turbo and start with 90. Should get it tuned at a lower temp because thats too hot to be running alot of boost.
Old Jul 3, 2005
Michalo187's Avatar
Abortion Survivor
I am manual running Stafford Fabrications with a return fuel system flywheel pulleys rsx injectors emanage tuned.
Old Jul 3, 2005
whoa serious?? The numbers you were and are making seem exactly like auto. I didn't realize lx is that much slower cause stock ex manual dynoes in at 100-110 whp, with sf kit 180whp tuned *without return fuel system, just kit.
Old Jul 3, 2005
civic01vtec's Avatar
With cooler temps, you should be around 190whp at 8 psi. Do you have the alcohol injection kit ????
Old Jul 3, 2005
Drk01Civic's Avatar
Drk01Civic is an unknown quantity at this point
You said your car "broke down" an hour after you left the tuner's shop? What happened?
Old Jul 3, 2005
Michalo187's Avatar
Abortion Survivor
No alcohol injection i plan to add that yeah i hope once it cools down i am up there a fuel line fell off and i wasn't getting fuel i just fixed it now its running again pretty dam powerful
Old Jul 3, 2005
gsrchad's Avatar
gsrchad is an unknown quantity at this point
160whp on 102 degree? WOW, why even tune when its that hot..
cuase if it gets cold out...your car would run lean... and thats not good..
but they say 1% hp increas for ever 10degree's.. not sure about Fi though... say 2%??
thast 30-40degree 8%... so 170 is surely avaliable..
Old Jul 3, 2005
Michalo187's Avatar
Abortion Survivor
i just tuned it because i didnt want it to get messed up once its cold i am taking it again. Hey but guys seriously for only having 160whp i am impressed how fast it is i will test it out maybe tonight against some friends if its safe since its a holiday weekend
Old Jul 5, 2005
HyaBoosta's Avatar
I dunno but by the sounds of it. Flooring it like crazy on the way home in 102deg. heat isn't the best thing for the car. did the temp gauge go up?
Old Jul 5, 2005
Michalo187's Avatar
Abortion Survivor
No it did not i floored it once just to see what it had the temp gauge has gone up once and that was after i raced that camaro i left it at idle and it went up but once i started driving it went down i am trying not to mess anything up because my dad has always been against me turboing my car and says the more you put on the more problems you can have so if i blow a head gasket he is going to kill me
Old Jul 5, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
it stoped and wouldn't turn back on because when you have a turbo car, you can't always be romping on it... can't always be at full boost. Gotta let it cool down some time. It'll happen in any car with a turbo... Not sure about saabs with water cooling though... thats where I got my turbo out of... I may hook up the water cooling.
Old Jul 5, 2005
Michalo187's Avatar
Abortion Survivor
My turbo is watercooled and intercooled
Old Jul 5, 2005
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
You need a bigger radiator, and perhaps an oil cooler, that will keep the temps down. Plus the water gauge is a pile. It really only reacts when it gets really hot, you cannot monitor subtle changes like an aftermarket gauge would. Basically, the ECU filters the temp gauge to keep it from moving around a lot and scaring the idiots that would make them think their car is doing something besides just opening the thermostat.
Old Jul 5, 2005
Michalo187's Avatar
Abortion Survivor
I want the koyo radiator i am planning to buy it pretty soon i think in Arizona a better cooling radiator is a must
Old Jul 6, 2005
BlackFire's Avatar
BlackFire is an unknown quantity at this point
158lbs-ft of torque is a great number for our cars at that temps. Not many Hondas matches the max torque with the max whp. So feel good with it!!!
Now... I'm not sure about why the car stops???..... Have it started again??
Old Jul 6, 2005
Michalo187's Avatar
Abortion Survivor
Yeah a fuel line in the gas tank was disconnected its doing good now its a lot faster than i thought it would be when i saw those numbers yeah the tuner was trying to get the same amount of torque and power on one tune he did but i told him i wanted more hp he got 156whp and 156 torque i told him to get a little more and thats when i noticed it was going up one horsepower a tune
Old Jul 6, 2005
BlackFire's Avatar
Good to know that it was just a disconnected line and it was not a major problem.
Congrats and have fun!!!
