Nitrous jet question???
Old Jun 23, 2005
Animosity's Avatar
Animosity is an unknown quantity at this point
Question Nitrous jet question???
i just got a NOS kit (yes its the holly NOS brand im not another dumb$hit that thinks all Nitrous kits are NOS). the kit is the pro fogger dry system. it has a 75 shot jet in it now, i need to find out what size jet to install to make about 30-40 hp. the motor wont handle the amount of nitrous this jet allows without fuel system upgrades. im going to get the solenoid and line to make it a wet kit but for now ill use it dry with a small shot. whats the smallest jet i can use and are all brand names compatable with the holly NOS systems???? please help
Old Jun 23, 2005
allmotor's Avatar
nor cal 7thgens
my NOS wet kit came with three jets 35-50-75. Are u sure u dont have the smaller jets? They should have numbers on the jets.
Old Jun 23, 2005
turboengnr's Avatar
DONT PANIC
if its a dry kit, there is a lot of retrofitting you would have to do to run it on your car (assuming you have a 2001+ civic, also assuming you didnt do a return line conversion).
Now if its a wet system, you simply need to change the pills. I would call the NOS tech line and get a base size to start with. Usually they set up the jets fat (rich), so i would have the car dyno tuned. Buy the jets that are 3 steps above and below on both jets (total of 14 jets) and play around with them on the dyno (closely watch the A/f Ratio.
Old Jun 24, 2005
Animosity's Avatar
mine is used it has only one jet. do you have the number for the techline
Old Jun 24, 2005
Animosity's Avatar
thanks for your help guys
Old Jun 24, 2005
allmotor's Avatar
nor cal 7thgens
yeah i will send a pm with all the #'s late tommorow
Old Jun 24, 2005
djmota's Avatar
I don't like running any dry kit in our cars, but I think a 25-30 shot should be safe.
Old Jun 25, 2005
allmotor's Avatar
nor cal 7thgens
my bad i forgot lol. I will find the directions and just post here prob tommorrow
Old Jun 27, 2005
Animosity's Avatar
cool thanks bro.
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
Uan
Aug 23, 2015 03:03 AM
martinsmartin
Aug 15, 2015 07:34 PM
