DIY PLX Wideband Wiring Instructions
Just a heads up, many companies, including my Zeitronix wideband, have failed to succesfully allow their products to simulate our narrowband signals. Most all will advertise that it will work, but only a few people have successfully got it right. The easiest and most common is to weld the 3rd bung in for the wideband.
The safest way is to do so.
Weld a bung is relatively low cost $30.00 and a wide band o2 sensor is only $55.
Very nice write up. And i assume it works flawless? would be nice to have this on the e-manage FAQ or something like that so its not lost!
Originally Posted by Havok2k1
I added it to the turbo faq so it won't get lost...
BTW maybe we could gather some known good Air / Fuel ratio numbers if anyone has some to base for All motor, boosted, and No2? IM kind of curious what others read for A/F like at cruise not under load, and when they let off of the throttle to coast down . Mine reads ultra LEAN to AIR! on deceleration.
Thenk the resistors and capacitors in the DIY are not necessary?
Originally Posted by ramcosca
Ha, feel like a two year old kid but... I'm not even two with Hondas, so here goes.
What the hell is a wideband?
lol
Thank you.
lol
Thank you.
Turbo Guru
Originally Posted by tfnaaf
Its a tool used to measure the Air Fuel Ratio of the exhaust gases
toastyghosty
32
Dec 26, 2001 02:03 AM
