Boost Controller NOOB question? help asap!
Old Jun 3, 2005
meseetree's Avatar
meseetree is on a distinguished road
Exclamation Boost Controller NOOB question? help asap!
Bought the HKS boost controller a while ago and i'm getting ready to hook it up. i know where everything goes except for where it says to go to the compressor suction pipe. is that my vacuume line???? what is it help please.
Old Jun 3, 2005
2K1Civic17"Gabe's Avatar
should be on the turbo itself. near the intake inlet. Thats the compressor inlet I believe, and it goes right on there. The other goes to the wastegate. Hope this helps.
Old Jun 3, 2005
meseetree's Avatar
that's what i thought but it tells me to put those two lines "tee"d together and then to the boost controller but then it says to go from the boost controller to the compressor suction pipe/source??????
Old Jun 4, 2005
civic2k2's Avatar
civic2k2 is an unknown quantity at this point
Nice choice in product but welcome to the wonderfully shitty world of instructions from HKS. If your not exactly positive what to do call up HKS themselves and ask they normally can tell you quickly what to do.
Old Jun 4, 2005
meseetree's Avatar
I found out from a friend what to do, the pipe was my intake pipe before the turbo. I am now running 8psi somewhat sucessfully.
Old Jun 4, 2005
civic2k2's Avatar
Just outta curiosity how do you like that boost controller, im considering getting one, is it easy to use, how well does it hold boost etc ?
Old Jun 4, 2005
meseetree's Avatar
so far it has been holding boost fine. actual setting it though was a little bit of a pain but it only took about 1/2 hour to set it correctly. with holding boost it has only been on the car for one night but i heard turbo xs controllers can't hold boost well so thats why i went with the HKS
Old Jun 4, 2005
glad you got it hooked up.
Old Jun 4, 2005
ohnoitssoysauce's Avatar
ohnoitssoysauce is an unknown quantity at this point
what was the highest anyone has boosted?
Old Jun 5, 2005
Mex's Avatar
Mex
Mex is a jewel in the roughMex is a jewel in the roughMex is a jewel in the rough
here's a silly question. do you really need to have a boost controller or is it just as safe to rely on only the internal wastegate to regulate boost? i plan on setting my boost at 8psi and never changing it, and i figure the only reason to have a boost controller is if you want to have that constant access to change it.
Old Jun 5, 2005
meseetree's Avatar
yeah my wastegate spring is a 4.5 lb spring. all the boost controller does is keep the wastegate from springing open at 4.5 and letting out all the pressure so yeah just have the wastegate set at 8 lbs and your good.
mex are you going down to virginia beach this year?
Old Jun 5, 2005
meseetree's Avatar
on stock internals????? i have an auto so i'm only running 9 psi since no one knows what autos can handle. for 5-speed civic01vtech has hit 13psi on stock internals and been fine. i think he runs 10 daily.
Old Jun 5, 2005
I have hit 13 as well, and boost 10 daily. manual 01 lx coupe, btw
Old Jun 5, 2005
meseetree's Avatar
nice.
I think i'm going to be the first to find out how much boost our auto trannys can handle.
Old Jun 5, 2005
what about someone who bulit thier internals, tranny all that stuff. i wonder what the highest someone has gone
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
Tarbris
Electrical
May 3, 2015 09:51 PM
viper775
Dec 9, 2001 10:52 PM
