Cyclinder Misfire
Old May 23, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
stl01civic is an unknown quantity at this point
Cyclinder Misfire
Got a cel fot ramdom misfire about 1.5month ago (all 4). Today ran it again though my scanner and got misfire cyc. 2 , cyc. 3 and cyc. 3.
Is it because I am running to lean?
List of mods:
HKS Log Style Manifold
Garrett T25 Ball Bearing Turbo
SF Fuel System
IK20 Spark Plugs
Johnny Racecar Intercooler
HKS SSQ BOV
AEM Cam Gear
AEM Tru-Time Pulley
Hallman MBC
Synapse Missing Link
Custom Made Intercooler Piping and Downpipe
Exedy Organic Clutch &
ACT XACT Streetlite Flywheel
Old May 23, 2005
djmota's Avatar
could be from running rich also. what psi
Old May 23, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
running at 6 psi b4. now turn it down to 4.5-5.
Old May 23, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
when i am on vac. it would be around stoich and when I go into boost it will go from rich/stoich to lean. Let off the gas/out of boost, it go back to rich.
(dam it, i should have gotta a wideband)
I am thinking it is the fuel system.
Old May 23, 2005
SODJAZERO's Avatar
SODJAZERO is an unknown quantity at this point
It could also be an issue with your spark plugs. They might need to be regapped. But see if you can get a wide band on it. A compression test wouldnt hurt either.
Old May 23, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
what should the plugs gapped at?
Old May 23, 2005
SODJAZERO's Avatar
should be .44, i know dsm guys who have theirs gapped at .32, are your running 93oct or higher?
Old May 23, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
running 93oct
have to stop somewhere and get a gapper first.
off topice: SODJAZERO - what kinda fuel system are you using?
Old May 23, 2005
SODJAZERO's Avatar
funny you should ask, i have guns old set up, with the alcy injection
Old May 23, 2005
SODJAZERO's Avatar
on a side note, the k20s should come pre gapped,
Old May 23, 2005
aznboysrfr's Avatar
DOHC i-VTEC TiMEX
check your plugs ... a few things happened to me when I was turbo'ed with the sf kit:
- the white plastic parts on the plugs cracked due to detonation, which caused my plugs to misfire (plastic was covering the spark electrode)
- sf fuel pump was cracked and leaking ... causing me to run lean and detonation (I didn't know until I sold the kit)
Old May 23, 2005
Michalo187's Avatar
Abortion Survivor
my spark plugs got messed up because i was running so rich i screwed them up they are very easy to **** up man
Old May 23, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I am getting to the point of doing a k20a3 or upgrade the whole fuel system to RSX-s Injectors w/ e-manage and tune it.
I really don't want to do a swap, because of all those $$$ I had alreeady put into this turbo (not to mention about the upgrade tranny (clutch & flywheel))
What do you guys think?
Old May 23, 2005
2K1Civic17"Gabe's Avatar
running 93oct
I only run 91 octane. That is all that is available to me in Phoenix. I think its because its so fuc*in hot here. Its been 104 and sh** the last few days. Winter can be freezing, but no snow or anything. I think thats why we only have up to 91 (other than race gas down the street)?? race gas is too much money.
Old May 25, 2005
HyaBoosta's Avatar
Turbo IK20's should be gapped about.30. check the plugs and their burn if not then you may be having fuel problems
Old May 26, 2005
02fpcivic's Avatar
02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light02fpcivic is a glorious beacon of light
mine did that alot with my emanage, i never figured out why or even tryed to figure out why. I was a temporary thing till I got the new comp.
Old May 26, 2005
stl01civic's Avatar
BOOSTED DOHC i-VTEC
I just turn my boost level down to 4 - 4.5 psi. Until I get some injectors, emanage, and tunning.
nola000
Engine start problems
63
Feb 17, 2023 09:18 PM
runawaykinms
15
Mar 22, 2019 10:32 AM
jtcavey
Sep 30, 2015 02:18 PM
Bruce2
Sep 27, 2015 08:45 PM
Luluharp
Sep 27, 2015 11:56 AM
