DirectportNitrous
DirectportNitrous
Is there any direct port setups that will work with our cars? I know we have plastic intake manifolds.
If so how much would it cost.
I think I'd get ZEX.
I know the manifold is plastic but I don's see why it can't handle it.
How about this kit on a d17a2?
http://www.powerandperformancenews.c...&Store_Code=ZX
Direct port isnt that hard to do on any of the B series. The only main difference is our mani is plastic but you can drill into that just as easily as you can aluminum so I dont see what the big deal is...if you wanna do it then do it.
Desperate Custom Swapper Speed Freak
Direct port nitrous bypasses ur intake manifold, so u wouldnt have to worry, cause its going directly into your cylinders with your fuel mix. So it wouldnt matter if ur manifold was made of alliminum or anything. So its fine.
FYI, the injectors u get r modified wit like another nozzle or something that sprays the n2o+fuel, which is supposed to give a perfect mix or something like that, so its the best to get. But I heard it can be hard on your engine.
except you wont have nearly the room you need. I already tryed it. You need a y8 or custom sidemount TB manifold for it to fit. Believe me all the parts are bigger than you may think once you start putting them together. I still have a kit that Im saving for a special project. hehe
Ever try mounting it underneath?
Thats no big secret ya know...and dont try to tell me it wont fit under there either because thats bull. on a d17??? ive seen it done many times too, on d16s and b series engines. The only one I saw on a d17 did puddle and did explode im not gunna argue, if you say it works for you then I guess Ill take your word for it dude.
DONT PANIC
hahahha. this is funny.
Direct port nitrous and a wet system are NOT the same. Also Direct port nitrous does not inject it straight into the cylinder. It is called "direct port" because it sprays the nitrous directly into the port leading into the cylinder. Most direct port setups are wet systems (meaning that they add more fuel via nozzle along with the nitrous). I have seen a direct port dry system, but we wont go there.
The idea of a direct port system is to evenly distribute the nitrous to each cylinder. It is SAFER than a normal single fogger system because of this. Also, it makes more power because it has the correct nitrous/fuel mixture in each cylinder. With a single fogger in the intake pipe, each cylinder gets a different amount of nitrous, causing some cylinders to run lean, and others rich. This means that you are hurting some cylinders with a lean condition, and also losing power.
The direct port nitrous system is THE SAFEST form of nitrous injection (in my honest opinion). Any other way (single fogger, dry system, plates) is just guessing and hoping.
I was under the impression that we were talking wet direct port setup. I agree that it is definetly the best way to go but if you have it underneath that manifold, given the limited space, it puts it really far away from the port(assuming that you cant wedge the nozzles in the flange under there somehow). I just cant see how fuel mist wont collect on the runners and settle into the bottom.
Nitrous backfires happen when nitrous is improperly used like spraying while the engine is off and then starting it and spraying at low rpms, etc.... I seriously doubt the one you saw that exploded happened because of the direct port and no I havent personally seen a D17 with direct port but I'm not a newb either nor am I stupid so why dont you calm down dude.
im not un calm hehe I think you took it wrong, im not saying you are dumb or anything like that. I just didnt want you to think i was just spitting random turds out of my mouth. When all the factors are taken into consideration the d17 manifold seems to be a poor manifold to set up with direct port. Any other honda would be sweet though. The manifold that blew up was a 75 shot at wot 5500ish rpms in second gear set up by an experienced tuner. It can happen, not the most common thing but it can happen.
DONT PANIC
you can do a direct port on any car. It may be harder on some than others, and the viable options may not be apparent at first, but you can do it on any car.
What would I do with our manifold? Well, i would do a 10,000 RPM style spray bar in a spacer plate that goes between our plastic manifold and our aluminum injector plate. I would have the holes metered to what my HP goals are (no jets). And i would have them up at the top and bottom of the runner, with just the very tip of the bar sticking out.
Now dont anyone go stealing my idea. I already have a machine shop building this spacer plate for my car. And if i see someone else with one before me, ill chop off your ***** and feed them to my cat!
That sounds like a lot of unnecessary work to set it up like that actually just to make it unique where as I would just take the easier route and even though I'm an advocate of nitrous, I dont mess with it anymore anyway so you wont have to worry about me stealing your idea.
DONT PANIC
lol. im not too worried about it. It is a lot of work, but it will be worth *most* of it. 10,000 RPM has been doing it like that for a long time, and they have been very successful with it. Theyve proven it to be extremely safe, and extremely efficient.
My cat will eat anything.
Crawlin Similar To An Ant Low To Da Earth
I am installing a ZEX direct port system I got from Street Level Preformance. It is true that it will be tricky with our mani but I bet it can be done...just have to put the jets in diffrent places front to back on the mani.
Originally Posted by gearbox
the green eclipse on fast and the furious has direct port nos and look what happened to it.
God i love that movie
